1600cvh best power
You see a few few 250s about. Personally unless you have deep pockets id just go with 200ish fast and more reliable. If your going for massive power there's better engines out there to do the job id say
Am running around 300 now so want it flat out lol just wanting to no what the big power one are using like water meth and things and management wise and I don't want a better engine I want to keep it a 1.6 cvh
NMS use a custom crank, rods and pistons into a relined Duratec block (IIRC) to bring it back down to 1600cc, they then extensively weld the head and re-machine it to achieve the desired flow along with larger valves etc, a custom NMS profile cam is ground by Newman with solid lifters, then it's manifolds and a suitable turbo, finally mapped by Karl.
I think last I spoke the cost was around Ł6000+
Simple fact of the matter is the blocks are just too old and weak now and nothing can be done other than go with a more modern block (zetec for example ). No two ways about it at 300+ it can't be reliable and you'll constantly be waiting for it to split. I could no longer live with that so I've gone with a new one.
From what a specialist told me it really comes down to the condition of the block thus the question is "How long is a piece of string?". He was saying that he is seeing many blocks that are now becoming brittle due to age and also down to how thin the walls are on a 1.6 CVH. The 1.9 is not meant to be as bad in this respect and neither is the Zetec bottom end.
I am running 225BHP on a ZVH and it has given me enough grief, albeit over silly things. I have done around 5-6k in it this year mind you, probably 3 times the amount it has done since the car was finally rebuild around 4 years ago and the engine 2 year ago (I'd have preferred the 1.9 long block to have stayed with the car but hey ho...).
I keep thinking about which route to go on my fiesta, want cvh as good to see when you open bonnet as looks original but the blocks being weak puts me off a bit on weather to low comp it or go zetec route
Am running around 300 Bhp on mine with no issues or reliability issues if there built right without cutting costs there fine am running 27 psi just wanting to no if to move onto omex and water meth I want to keep going with this engine to see what I can get I no it's a 1.6 cvh but that makes it more of a challenge
Std crank ish
Proper rods and Pistons
Fully worked head with steel billet cam, roller rockers
Field motorsport spec Rolled bearing turbo
Jenvey throttle bodies
Ava exhaust manifold
Dry sumped
With f88 rs ecu
Roughly
Dry sumped
With f88 rs ecu
Roughly
Gus your car is the bollocks mate, one of my fav RS turbos ever.
I had an NMS 1600 cvh for around 7 years and it gave me no grief at all and was 100% reliable the whole time.
Was 300hp and 300 torque at just under 2 bar boost.
I loved it.
Weak point as already mentioned is the blocks.
I had a thicker walled series 1 cvh block in mine and it was as good as gold.
I was gonna take the power up further and change the spec but instead I sold it to fund going the Cosworth route.
Cheers Paul
I loved it.
Cheers Paul
My car is not a powerhouse by any standard. Years ago it used to make 270BHP from a 1.9 long block using KE-Jetronic and a 5th injector. It is now on a 1.8 ZVH making 225BHP. IMO there is a little more to come from the car (the charge temps have been reduced since the last RR and I am not convince the cam timing is all that on the car) but we shall see. I certainly will not get beyond 240BHP with the above tweeks IMO. It is still on the above injection setup running well for the best part, albeit not perfect (the fuel pump needs 'priming' via the ignition key for it to start first time if left for more than a week, the cold starting (from dead cold) could be better but the cold start injector is not wired up. I want to check the wiring before simply hooking it up to rule out a few things (i.e a bodged loom).
Gus, that looks like a lovely build and it sounds like it has the spec to match. It would be interesting to see the full spec of it. That must really be a flying machine!
What's your spec?
I'm looking into roller rockers just now ( what's your thoughts on them ) can get them for 330 in the states
Blair
I'm about to buy a set from States ( from a 1.9 cvh but I'm told they will fit ) ?
I have a newmans cam and solid lifters - will this be ok to use the roller rockers? I would like roller lifters but sounds a lot off hastle
Many thanks
Blair
And if I can use them with newmans cam and solids?
Any help would be appreciated
My spec is
Wossner pistons
Pec rods
Newmans cam and solids
8.5.1
Roller rockers
Big valve head
Standard matched manifolds
Would it be safe for 7500?
Im no expert by far, but pretty sure head spec would be fine for 7500rpm,,
My cvh head on my zvh was still on standard rockers at 7620rpm BUT no guarantee it would last very long! Actually the stud holes for the rockers where modified! Which supposedly makes a differance,
You should speak to harland sharpe in the states for roller rockers, i was speaking to them about a set before i decided to go zetec turbo
