Mondeo heated seat NOT elements
Old Oct 27, 2015 | 06:48 PM
rareti's Avatar
rareti
Default Mondeo heated seat NOT elements
Hi all! at my wits end !!!!!. Mondeo 3 Facelift driver heated seat not working and it does not seem to be the pads . with my limited knowledge with multimeter, I have stripped seat and all seem to me to be fine, no resisitance where I would expect none and resistance where I would expect it. Climate fan working -just not the element pad heating. Passenger seat working perfectly- so presume not fuse and not relay. The switch illuminates red/heat, blue/cooling, as it should. Can switch illuminate but not work to the seat???
I dont seem to have any terminal in the multiplug from the floor to the seat becoming live when I switch on- but I dont seem to have any terminal becoming live when the fans for cooling come on either- yet they work!!!!
Can anyone help? or have experience of something other than pads, relays and fuses making a seat not work ????
thanks in advance
Old Oct 27, 2015 | 07:33 PM
st220kyle's Avatar
st220kyle
Just test for voltage at the connection for the actual heated seat, if theres 12v there the pad is knackered. Makesure your meter is set to DC.
Old Oct 27, 2015 | 07:44 PM
dojj's Avatar
dojj
Resident Wrestling Legend
The pads can give up and still show a circuit
Fairly common
Old Oct 27, 2015 | 08:05 PM
rareti's Avatar
rareti
I dont seem to haveany terminal in the block connector from the floor/loom getting any voltage when I switch on the switch.Also the seat base ANDthe back arent working (which they both were).If an element ,either shud work and not the other(unless the pads in the back ANDthe pads in the base both packed up at around the same time). Ss said cant find any voltage -yet fans work !!!!
Old Oct 27, 2015 | 10:04 PM
dojj's Avatar
dojj
If it's the heater cooled seats they have a little box o tricks in the seat base which does the heating and cooling
If this is kaput it could also be the case
The wires of the facelifted seats are in different places to preface buy the colours are the same if that's any consolation, I'd let you know exactly what was what but I'm not home till 2am
Old Oct 28, 2015 | 07:18 PM
rareti's Avatar
rareti
That box seems to b ok as well. I have resistance across the terminals in the block connectors. In th feed from the loom in the floor,I have 1terminal perm live-this seems to be the seat motor.i have another live when the ignition is turned on.when I switch the seat heat on ,I dont get any other terminal live. Is this correct?? Is the switch switching the earth or something???
Old Oct 29, 2015 | 01:40 PM
dojj's Avatar
dojj
There is a box o tricks under the dash too
Old May 16, 2016 | 05:59 PM
cossiejay's Avatar
cossiejay
very very late reply but mine has heated seats but no relay installed what the hell is that all about
Old May 16, 2016 | 06:19 PM
visa_broke's Avatar
visa_broke
10 Year Member
not sure on these but on another brand I used to work on the relays was built into the switches instead of seperate
Old May 16, 2016 | 07:43 PM
cossiejay's Avatar
cossiejay
someone has removed it or ford never installed it as when i put one in seats work
Neil Mcclary
Fiesta ST
24
Nov 16, 2015 08:52 PM
Graham Taylor
Oct 27, 2015 08:45 PM
Steve Escos
Oct 26, 2015 11:07 AM
Andyrangy
Oct 21, 2015 04:44 PM
westyre1
Oct 21, 2015 02:40 PM
