Track day checks
Old Oct 21, 2015 | 11:48 AM
gingeRS's Avatar
gingeRS
Default Track day checks
right i'm on track in a couple of weeks, booked a day off a couple days before to give the car a quick check over.
usual stuff, gonna fit some fresh oil and new filter, check all my levels.
my brake discs are a little warped, should i get em skimmed in situ or replace with new (worried about only having 100 or so miles before track so might warp new ones) maybe use the old pads or fit some new?
tyres are new, got some new plugs to go in, car is the Focus RS in my sig.
any more suggestions from the track regulars
Old Oct 21, 2015 | 12:41 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
All the usual fluid and maintenance checks. probably new discs and pads in your situation. Check the accessible suspension bolts and wheel bolts with a torque wrench.
Empty out the junk.
Old Oct 21, 2015 | 12:50 PM
gingeRS's Avatar
gingeRS
gonna check the disc thickness at the weekend to see if they are ok for skimming
Old Oct 21, 2015 | 01:13 PM
M K's Avatar
M K
What track day you doing mate?
Major check is wheel bearings! Seen a lot of people with ruined wheel bearings halfway through a day due to extra high cornering speeds they don't normally do on the road,
Another check is screen wash, as flat out you may need it especially this time of year with a likely wet/damp track with spray,
All fluids
Brakes
Clutch
Oil
Gearbox
Power steering
Tyre tread to make sure they will last the day AND GET YOU HOME LEGALLY! Easy to get carried away then realise there bald at the end of the day lol
Tyre pressures, best to take a foot pump as you may want to alter pressures to suit and return to normal to drive home
Make sure you have both tow eyes and have them fitted before you get out on track
Lastly empty all the loose crap from the car before going out on track
Old Oct 21, 2015 | 08:09 PM
nigel b's Avatar
nigel b
check your wheelnuts
Old Oct 21, 2015 | 10:16 PM
maxest's Avatar
maxest
And not straight after a heavy session.. Snapping your wheel studs.. I've never done that
Old Oct 22, 2015 | 07:39 AM
BigChuck's Avatar
BigChuck
I'd advise against skimming if they are warped, as soon as they heat up they will warp again.
Old Oct 23, 2015 | 02:02 PM
gjh's Avatar
gjh
Ye get new discs, as above, they'll only warp again, they are going to be used harder than they ever will be on the road.
Old Oct 25, 2015 | 09:11 AM
gingeRS's Avatar
gingeRS
do i want to fit new discs before going on track though, dont i need some gentle use before to heat treat them a bit
thanks for the other advice guys
Old Oct 25, 2015 | 11:29 AM
BigChuck's Avatar
BigChuck
Your choice is either new disks or go with warped discs that will only get worse.
I wouldn't fit discs and go straight on track, if you can get them out and bed them in a bit before hand, 10/20 miles would do it
Old Oct 25, 2015 | 11:33 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the brakes will be cooked on track in any case, so just do a quick bleed of the calipers to make sure there's good fluid in the calipers and then see what happens with your current set up
once you know they aren't up to track day use then perhaps you can go the upgrade route rather than just on a standard set of discs/pads
Chopshop85
Oct 22, 2015 09:26 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
Daniel Howard
17
Sep 26, 2015 12:39 AM
Vacuman
Sep 22, 2015 12:09 PM
