Old school audi coupe brake upgrade?
As title my mrs has audi gt coupe 2.2 1987 on a D reg! Im currently doin few jobs on it for her an wondering if theres a brake upgrade anyone knows off apart from AP route cos of cost. Brakes on it are like brakes on std cossie n just up to the job
Engine is gonna be fettled with maybe turboD so no use goin fast if you cant slow it down
Any info will be greatly appreciated
I would look on the Audi forums, a lot of the vw Audi stuff can be swapped. The VR6 calipers and discs may fit, they are good and you can put good pads in there.
The Porsche Boxster stuff may even fit with a bit of work or maybe Porsche 944 turbo....get googling and I bet you will find something.
Often some quality oe discs, new fluid and some uprated pads and brake lines can do wonders, especially if there is any adjustment in the Clevis pin on the foot pedal. A different master cylinder or servo can also do a lot.
The newer stuff is 5 bolt, so if that's the case then it's fine
But you will obviously have issues fitting the big kit under 14's so the budget needs to allow for bigger wheels too
