Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Your most useful tool that's not a tool
Old Oct 17, 2015 | 09:01 PM
Vacuman's Avatar
Vacuman
Default Your most useful tool that's not a tool
On and off for over 30 years I've made use of a long piece of steel pipe that started life as the outer part of a 3.0 Capri steering column.
If ever I need a bit more leverage on a ratchet or, more usually, to loosen wheel nuts overtightened by Kwiktwat, this magic bit of Ford tubing does the trick.
What non-tool item have you become reliant on over the years?
Old Oct 18, 2015 | 08:26 AM
I used to do the same till i broke the teeth on a few ratchets lol.
Old Oct 18, 2015 | 09:55 AM
costina's Avatar
costina
Live long and prosper!!
A mate called Glenn.....
Old Oct 18, 2015 | 10:18 AM
Colin_P's Avatar
Colin_P
I'd say a laptop computer.
Read a fault code then come indoors to research it using the laptop, then get bored and look at boobs again using the laptop
cozzy jeff
31
Aug 17, 2016 03:07 AM
cossie330
Oct 7, 2015 08:22 PM
rik-rs
Oct 4, 2015 09:06 AM
jonnyenglish
Sep 21, 2015 07:31 AM
