ISCV operation HELP !!!!!!!!!!!!!
Fololowing on from the problem with the running of my car.
The latest is that i have noticed that the ISCV operated when the engine is hot.
I can take off / on the plug on the ISCV and hear it clicking.
When engine gets upto temp should this not opearte and be closed.
Regards
Regards
Hi
Base idle correct 900rpm
TPS set as i have just fitted replacement...
Does the Coolsant temp sensor have anything to do with the ISCV....
xr_craig
24
Oct 18, 2015 05:01 PM
Fatphil
Oct 15, 2015 10:02 PM
