Full braided lines from mastet cylinder to calipers.
Old Oct 16, 2015 | 06:37 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Default Full braided lines from mastet cylinder to calipers.
Fitted these lines to a car which had been converted from having ABS to NON ABS by a well known company. Funny thing is I have 2 cars here both done by same person, both with massive brake issues. Both had been bodged back together to get out the door.
For future reference. If you want to remove the ABS ffs do it right. No amount of extra lines linking up pipes and splitters is every going to be right. You will need to remove the compensators from the rear of the wishbones. You will require compensators on the inner drivers side wing. All lines need removing. 4 Port master cylinder is required available new.
Then you might actually have brakes that work
Not an advert so dont bother being a grass for no reason. For education reasons and helping others save $.
Attached Thumbnails Full braided lines from mastet cylinder to calipers.-1444735481388.jpg   Full braided lines from mastet cylinder to calipers.-1444735082943.jpg   Full braided lines from mastet cylinder to calipers.-1444731567896.jpg   Full braided lines from mastet cylinder to calipers.-1444735442757.jpg   Full braided lines from mastet cylinder to calipers.-1444732791100.jpg
Old Oct 16, 2015 | 06:48 AM
haz87's Avatar
haz87
I've never seen the logic in using braided all the way. Copper/hardline performs better for a start.
Looks over safety/performance :/
Old Oct 16, 2015 | 06:54 AM
Versus_Creations
Ask me a question!
Well sadly the std hard lines are not only hard to find but most are damaged or corroded.
The myth about braided lines feeling worse than copper or hard lines is rubbish. Yes no doubt there is expansion. But not to a point you can feel it or it effects the brakes.
I hate copper. It looks naff far from tidy and last thing I want inside my car is shite copper.
The braided lines are awesome in every way. From looks to function.
Old Oct 16, 2015 | 10:10 AM
Caddyshack's Avatar
Caddyshack
Why do you need to remove the rear compensators?
Old Oct 16, 2015 | 10:32 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I see the man from ap on tv once on the build a race car series say ideally you need as much solid pipe and as little flexible pipe as possible as the flexible pipe will expand and you loose pedal feel
Old Oct 16, 2015 | 02:32 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
If I was replacing all the lines on a car I'd use Kunifer hard lines, installed neatly they look fine, will never rust, degrade or swell and are not expensive.
Unless the customer specifically wanted something else of course.
Old Oct 25, 2015 | 06:45 PM
stuart collins's Avatar
stuart collins
mine is all braided and no problems with it
Chopshop85
Oct 22, 2015 09:26 PM
massivewangers
30
Oct 1, 2015 07:40 PM
IainRS1700T
Sep 25, 2015 06:44 AM
davidfordrs
Sep 21, 2015 04:23 AM
Flatlinedan
Sep 18, 2015 12:41 PM
