Saffy anti roll bar on 3dr?
I have put new bola wheels on my 3dr, 17 inch, and the front wheels sit quite far forward in the arches. If I fit a 2wd saff anti roll bar, will this pull the wheels back slightly? I've heard it will, but want to check.
I'll have to take a look. It may have a saffy one on it. 😳
Mine is a late E plate, so assuming it has the same as the saffy.
I would like a H13 to make the wheels sit backa bit diff I can find one.
All the 2wd ARBs , early or late sit the wheels in exactly the same place ,, the only one that pushes the wheels forward in the arch is a 4x4 saff item
I have a H13 and a H14 arb here
I have checked them and the most i can get is a 3mm between the 2 ( the H14 BEING THE LONGER ) so thats the 1 degree gain.
I doubt that will cause you any big issues .
You can quite clearly see that the shape between H13 / H14 is totaly different .
Cant you move the front bumper forwrd a tiny bit ?
Going back to the H13 will make the car drive worse ,, even more so if you have bigger wheels
I have never had any issues with the rs500 or later 3 doors that has the H14 fitted as std
Jack and the Beanstalk
38
Sep 8, 2017 07:56 PM
