Oil recommendations?
Old Oct 4, 2015 | 09:52 PM
frug's Avatar
frug
Default Oil recommendations?
I know it's probably been asked a thousand times, but what are people's recommended oils for yb engines?
I've finally got our project up and running, and since the engine hadn't run in a long time, we drained out the old oil, and replaced with some cheapy 10w40, ran the engine for 15 to 20 minutes till it was warm and the oil coolers had circulated for a while, then drained again and replaced with some more of the same. however there is a slight chattering noise from the distributor pulley area, which mainly occurs around 1500 rpm and only within the first couple of minutes after starting up from cold, oil pressure looks OK (45psi cold, taken at the turbo oil feed, dropping to around 35psi after warming up a little). Would a thicker oil be likely to quieten it down a little? I've slackened off the timing belt and can only feel a millimeter or so of in and out play on the pulley, and no up/down or side to side play at all, also, the timing belt runs out by a couple of mm on the same pulley, is this fairly normal or cause for concern?
Old Oct 5, 2015 | 10:19 AM
oilman's Avatar
oilman
Hi
If it's modified, a 10w-50 is likely to be the best option.
http://www.opieoils.co.uk/c-659-10w-50.aspx
The Nanodrive CFS is, on paper, the best oil available, but the Pro S, Red Line and CFS are really good oils, so all are good choices for your car.
Tim
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Bailes1992
49
Dec 25, 2015 02:18 PM
A.t.p
Oct 23, 2015 07:54 PM
Mc5506
Oct 5, 2015 09:57 PM
deathrider666
Sep 28, 2015 06:12 PM
