Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
top and bottom radiator hoses are both cold after running car for half an hour
Old Sep 24, 2015 | 01:42 PM
mk1focus's Avatar
mk1focus
Default top and bottom radiator hoses are both cold after running car for half an hour
ive brought a mk6 2003 ford fiesta 1.6 I changed the coolant and now when I run it both radiator hoses are cold is that normal? also radiators cold, ive took cap of and put the heater on full and ran it to get there air but still cold but the heater blows hot also the temp gauge says norm, any ideas?
Old Sep 24, 2015 | 04:14 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Sounds like a serious air lock and I wouldn't run it for long without rad getting hot. I would be looking at the thermostat first as it could be stuck in warm up mode. At the very least have the heater on full hot until you get to bottom of it but I wouldn't go far.
A quick google suggests heater valves commonly stick and water pumps can fail so I would swap out the above 3 to rule them out.
Old Sep 24, 2015 | 04:36 PM
mk1focus's Avatar
mk1focus
Thanks for the reply, will change thermostat and let you know how I get on
Old Sep 24, 2015 | 06:19 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Good luck!
track.focus'd
Aug 12, 2015 05:53 PM
Adam-M
22
Aug 10, 2015 10:46 AM
yawiejon
15
Aug 9, 2015 06:36 PM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
nuttynil
PassionFord FAQs
Jul 31, 2015 10:21 PM
