3dr front suspension??
Old Sep 22, 2015 | 06:55 PM
martynhomer01's Avatar
martynhomer01
Default 3dr front suspension??
Hi guys, I'm baffled!!
I had a lot of play and brake judder from the front of my 3dr, and on closer inspection, found the ball joints on the front control arms knackered, the tie rod ball joints gone, and it looked like the bushes in the front control arms had worn.
I replaced the complete arms with brand new units, standard bushes, and replaced the tie rod ends.
Test drove it today and the judder has gone, but I can still push the front wheels back towards the car body as there is a lot of play there?
When you brake, the front wheels move backwards about an inch or so!
I'm really baffled. And ideas?
Old Sep 22, 2015 | 07:50 PM
james kiely's Avatar
james kiely
Could your anti roll bar bushes be gone Marty?
Old Sep 22, 2015 | 08:13 PM
martynhomer01
They're poly bushed James and new.
Done some research and I reckon the washers for the arb to tca could be wrong or the wrong way round?
I have really dished washers on the arb and have them facing like this )-(
The tca bush being the - and the washers facing outwards?? This wa how they were fitted so I put them back that way?
I thought the washers should be flat myself?
Old Sep 22, 2015 | 08:14 PM
Harris.'s Avatar
Harris.
Fit a 2wd saff front roll bar with powerflex bushes , moves the front wheels 5mm forward and gives a better turn in also
Old Sep 22, 2015 | 08:17 PM
martynhomer01
Originally Posted by Harris.
Fit a 2wd saff front roll bar with powerflex bushes , moves the front wheels 5mm back and gives a better turn in also
Sounds like a plan, but surely the 3dr anti roll bar should stop the wheels moving back? Have I got the washers on wrong!
Old Sep 22, 2015 | 08:21 PM
james kiely
Sounds like the washes are correctly fitted Marty.whats your top mounts like?
Old Sep 22, 2015 | 08:23 PM
martynhomer01
Top mounts are new too James. The movement is between the tca and the arb. I think I'll have to polyflex them, but I thought the standard bushes would be man enough?
Old Sep 22, 2015 | 08:26 PM
Ridgey's Avatar
Ridgey
Are you sure the arb mounts are securely fixed, it is the arb that fixes the wheel in the forward position.
Is the top of the suspension securely fitted as well?
Old Sep 22, 2015 | 08:30 PM
martynhomer01
Yep, been through the whole suspension set up, checking bolts etc. top mounts are tight, anti roll bar bolts are tight, brackets are tight and all ball joints etc tight.
If you grab the tca and push it back, it goes back and the bush in the tca flexes allowing it to. That's why I thought it could be the washers?
I'm fuckin baffled!
Old Sep 22, 2015 | 08:32 PM
Ridgey's Avatar
Ridgey
Do the washers snugly fit the std rubber bush?
Thought I recalled the std bush to be thicker in the centre.
Old Sep 22, 2015 | 08:34 PM
Ridgey's Avatar
Ridgey
So washers would need to be like ()
To stop forward/reward flex
But I've not had std on my car for years so not 100%
Old Sep 22, 2015 | 08:39 PM
martynhomer01
No they don't, the centre does but the outside is away from the bush.
thats where the flex is coming from?
Old Sep 22, 2015 | 08:41 PM
martynhomer01
That's what I thought.! So if I fitted polyflex tomorrow, do the washers need to be () or )( ?
Also, what's the best way to get the standard bushes out?
Thanks so far guys!
Old Sep 22, 2015 | 08:43 PM
Ridgey's Avatar
Ridgey
Just looking at the Workshop manual and as you describe seems correct.
The power flex washers go )( as well.
The rubber bushes can be tapped out with a screw driver from the edge, as there is a metal edge band on them
Old Sep 23, 2015 | 12:23 AM
JPA's Avatar
JPA
Thanks so far guys!
Hi Martin
Washers go this way whether it's standard bushes or uprated ones of some type ) (
Also standard bushes allow quite a bit of movement as their name would suggest " compliance bushes "
This is not a fault as it's designed this way , I did find it funny aswell when I was MOT testing Sierras many years ago
John
hopper350
Sep 4, 2015 12:53 AM
StephTell
Sep 2, 2015 06:31 PM
C2 MAK
Aug 20, 2015 09:46 PM
TrevCos
Aug 17, 2015 09:08 PM
Old ford
Jul 31, 2015 06:50 AM
