Group A coil or not
Hi all, want to replace my current cheap europarts ignition coil on my 144bhp ERST not sure im getting a decent cold start spark.
Should I get a group A coil or is this a bit unessasary
or a standard bosch coil? http://www.burtonpower.com/bosch-blu...221119027.html
and.... do I need the little ballast resistor?
Thanks in advance folks
I recently got a group a one on email for 15. Bolted in but not tested but it seems to get good reviews on a number of forums
Thanks simonmcf, yeah seen some aswell but usally quite highly moded cars
I would get one but you have to get the loom aswell so for the sake of just spending money after money do I acually need this or will the bosch coil be more than enough
cheers
cheers
I've had a Magentti Marelli group A one on my ERST for several years an it's still going strong. Was only £7 more than a bosch std replacement and there's no loom for them, you just change the connectors to spade. They'll even fit using the original bolt holes.
The loom is just a rely that is triggered from the original coil wiring which then switches a feed direct from the battery to the coil. That way you no you have good voltage at the coil and not power going through old wiring that could have a resistance in it
Thanks for your replys folks, think i'll go for the grp a with a new loom
Coil
http://www.ebay.co.uk/itm/1517385418...%3AMEBIDX%3AIT
Loom
http://www.ebay.co.uk/itm/1718005405...%3AMEBIDX%3AIT
Thanks again
Coil
Loom
Thanks again
No harm in that.
There is no point going with an aftermarket coil ; I have had no end of trouble with them, often giving me more issues than when I had the original item on?
However, check your wiring and ensure that you are getting 12V at the coil.
davidfox280585
Shows & Track Days
Sep 17, 2015 10:09 AM
