Mk3 conversion problems! Please help
Old Sep 15, 2015 | 08:51 PM
liamT74's Avatar
liamT74
Default Mk3 conversion problems! Please help
Hi all just asking for a bit of info....
I have two 1.8 16v gti engines with box's, gti engine loom, ecu, transverse and key, rad and basically everything in the engine compartment.
Iv just picked up a mk3 fiesta si 1.6 16v engine and basically the same as the one load out of the gti.
Questions I have....
Can I use the 1.6 efi manifold and would it make a difference in performance?
Could i use the gti rad?
Can I use the si loom and not lose power when I do the conversion,?
This is in regards to putting the 1.8 in the mk3
Old Sep 15, 2015 | 09:46 PM
luke89's Avatar
luke89
Team HOTHOT!
Wouldn't bother with 1.8 , use a 2.0ltr with the 1 .6 sump and water pump , si 1.6 loom with mondeo deep desk or dewy ecu only bit on the 1.8 I would use is the inlet
Old Sep 15, 2015 | 11:00 PM
liamT74's Avatar
liamT74
Ai I'm happy just to drop the 1.8 in for now, I got 3 engines sat there and for me to go out and buy another I would deserve a kick, the 1.8 manifold is a plastic type and the 1.6 is the efi type. I'll use the si loom for now and the escort ecu, I'll have enough spares to drop the 2liter in then and all I'll need to pick up is a ecu I suppose, and the inlet manifold
Old Sep 15, 2015 | 11:09 PM
liamT74's Avatar
liamT74
Don't quote me on this,but an it there only 15bhp difference between the escort gti 1.8 and the mondeo 2.0l ? If I pick up a 2.0l I'd quite happily strip it and rebuild it and go all out
Old Sep 16, 2015 | 08:36 PM
luke89's Avatar
luke89
Team HOTHOT!
Yes but the have more torque, can't help with the 1.8 as I only used 2.0lts , oh the plastic inlet won't work on the fiesta try find a rs1800 ho inlet sure u can still run the 1.8 on the 2.0ltr ecu , what are the codes of the ecu that you have ?
Old Sep 16, 2015 | 08:41 PM
liamT74's Avatar
liamT74
[QUOTE=luke89;6624247]Yes but the have more torque, can't help with the 1.8 as I only used 2.0lts , oh the plastic inlet won't work on the fiesta try find a rs1800 ho inlet sure u can still run the 1.8 on the 2.0ltr ecu , what are the codes of the ecu that you have i only know the one witch is (slug) came off the escort gti I scraped, how come the plastic 1.8 manifold won't work in a fiesta ?
Old Sep 23, 2015 | 08:59 PM
Andypandy260's Avatar
Andypandy260
I know that the 1.8 rs1800 engine in the fiesta have the same cams as a 2.0, that twinned with a bigger throttle body got it up to 130bhp. So doing that means you don't have to mess around finding a 2.0
Old Sep 23, 2015 | 09:14 PM
liamT74's Avatar
liamT74
[QUOTE=Andypandy260;6625823]I know that the 1.8 rs1800 engine in the fiesta have the same cams as a 2.0, that twinned with a bigger throttle body got it up to 130bhp. So doing that means you don't have to mess around finding a 2.0
so could I use the plastic manifold ?
Old Sep 23, 2015 | 09:28 PM
Andypandy260
Mines got the cast manifold on it, think people use that because it's only one that fits within the space between the engine and the bulkhead.
Old Sep 23, 2015 | 09:32 PM
liamT74's Avatar
liamT74
Awwh right, well I have a 1.6 to drop in for now, just need a powered steering rack, I'll seek out an alloy manifold the 1.8 or look for a 2.0l with one on. Think I'll start hunting for a mk4 escort as the next project
Old Sep 23, 2015 | 10:24 PM
Oranoco's Avatar
Oranoco
Unfortunately it never actually did make the claimed 130bhp and almost every RS1800 and 130PS Zetec I've seen has been nearer the 115 to 120bhp and always significantly less torque that of the 2 litre.
155lee
Sep 6, 2016 11:10 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
Flateric_2002
Sep 15, 2015 08:41 AM
fordfiestamk3
Sep 11, 2015 12:52 PM
Bighandsuk
Sep 2, 2015 05:23 PM
