Boost control - Talk to me
Old Sep 6, 2015 | 01:15 PM
markk's Avatar
markk
Default Boost control - Talk to me
Ok, probably getting ready to think about boost control, the car is an escort cosworth and I am in no way nostalgic in thinking I need to have air injectors, of in the case of the WR cars twin air injectors, so what is the options, something bleed off, fast solenoid that I can control, nice quick PWM.
How about one of these
http://www.ebay.co.uk/itm/3-Port-Ele...item2ecd67bcef
Good ? yes?
What have you used? (and did it work - please nothing manual)
Old Sep 6, 2015 | 02:27 PM
Jan300's Avatar
Jan300
Im using one with L8 ecu and working good.Was easy to take control of the boost when turbo surge.
Good ? yes?
Old Sep 6, 2015 | 03:39 PM
M K's Avatar
M K
Il be switching to a 3 way boost solenoid as soon as I can
Old Sep 8, 2015 | 11:00 AM
stevieturbo's Avatar
stevieturbo
C**t
Good ? yes?
The MAC solenoid is pretty much the standard on aftermarket boost controllers.
Cheaper seller albeit US.
http://www.ebay.co.uk/itm/MAC-Boost-...item4d2462b654
Some others prefer the Pierburg, which apparently is a little faster than the MAC.
http://www.garagewhifbitz.co.uk/inde...-solenoid.html
I can see no reason to go with the expense and complication of air injectors.
Old Sep 8, 2015 | 05:12 PM
The Youth.'s Avatar
The Youth.
after using a amal valve on my race car with poor results (boost would sway 3/4 psi until at high rpm)
I moved onto a single MSD air injector and it transformed it, perfect boost control giving me the exact boost required every time, can't recommend it enough
a fit and forget solution
steve
Old Sep 8, 2015 | 06:31 PM
stevieturbo
C**t
That's because the old Amal valve is shit.
Old Sep 8, 2015 | 07:04 PM
markk's Avatar
markk
Mac ordered from the states. 👍
Old Sep 8, 2015 | 08:19 PM
Marc sierra's Avatar
Marc sierra
Can such a valve be used with an L8 instead of an amalvalve? I still need something to control boost as well, but I would like to have the ecu to lower the boost when needed. And I also prefer the bleed off method.
Old Sep 8, 2015 | 09:54 PM
stevieturbo
C**t
If the ecu is capable of PWM'ing the output, then yes it can use a 3 port solenoid.
Likewise if it can drive air injectors, then it could also run the solenoid instead.
Old Sep 9, 2015 | 08:11 AM
Arran @ Motorsport Developments's Avatar
Morning chaps,
We Have some mac 3 port solenoids on the way, once they arrive we will be testing them in-place of an amal valve, so watch this space for results.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
