Starting problems
Old Sep 2, 2015 | 01:43 PM
kevin36's Avatar
kevin36
Default Starting problems
Hi, I have an 88 rs turbo. I cleaned out the breather pipes and now I cant get the car started. can anyone give me any advice???
Old Sep 2, 2015 | 04:10 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
wires to amal valve can come off,, should hear 2 little clicks when putting ignition lights on
Old Sep 2, 2015 | 04:33 PM
kevin36's Avatar
kevin36
AMAL VALVE??? What and where is this? thank you
Old Sep 2, 2015 | 05:53 PM
mk2grp1's Avatar
mk2grp1
under the dizzy, usually on a bracket bolted to a gearbox bolt , left of the clutch cable .
3 small vac pipes connect to it
Old Sep 2, 2015 | 06:24 PM
gcfcos's Avatar
gcfcos
All I can suggest is check every connection in the areas where u have worked on it
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
