T5 gearbox, Std/Std crank, 200 block, big wing sump
Old Aug 27, 2015 | 10:13 AM
James Porter's Avatar
James Porter
Default T5 gearbox, Std/Std crank, 200 block, big wing sump
This was for a build that I was doing but now sourced a complete running gear.
2wd T5 gearbox from a totally standard Saff, fully tested with no issues at all. Car had 60k but can't guarentee it's the original box.
£600.
Standard/standard crank, again came from the 60k car was still running the original Ford shell's.
£1000.
Long studded 200 block believed to be on 0.5mm oversize. Bores are good.
Bare block with caps & 6 long studs.
£750.
2wd big wing sump, I've not properly looked at this but has a 2 litre add on at the one side
£175.
205 block with standard Pistons & rods NO crank.
£350.
I also have a set of Leda Grp A coil overs with remote reservoirs & adjustable top mounts. Will add a price soon as I'm not really sure what to ask for them.
Can post anywhere in Europe if needed
J.
Old Aug 27, 2015 | 07:16 PM
Brocker's Avatar
Brocker
The Leda Suspension could be iteressting for me
Old Aug 27, 2015 | 08:01 PM
James Porter
PM sent
Gearbox provisionally sold
Old Aug 27, 2015 | 08:45 PM
IainRS1700T's Avatar
IainRS1700T
PM sent
Old Aug 28, 2015 | 06:24 PM
James Porter
Sump & gearbox sold
Old Oct 27, 2015 | 10:39 PM
kiwikermit's Avatar
kiwikermit
Do you still have the 200 block?
Old Oct 28, 2015 | 12:17 PM
PF Ben's Avatar
PF Ben
James, who did the long studding and can you measure / confirm on 0.5 oversize please? Genuinely interested just want these points confirmed before parting with my hard earned thank you
Ben
Ford Classics & Vintage
12
Apr 9, 2019 08:24 PM
Rsmat
63
Sep 25, 2015 12:11 PM
mint_s2
Sep 2, 2015 08:58 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Blown Hell
Aug 5, 2015 07:22 AM
