cossie 4x4 manifold heat wrapping??
Old Aug 25, 2015 | 04:03 PM
frug's Avatar
frug
Default cossie 4x4 manifold heat wrapping??
Has anybody managed to successfully wrap a 4x4 manifold? I'm curently on attempt 3 of putting on/taking off the wrap as i just cant get it to form neatly around the area where all the runners collect.
Just wondering if anyone has any experience or some sort of a top tip, before i pull out the last of my hair! There's no other option for it either, we need to get the manifold well insulated as there is so little room between that and the boost pipes coming from the cold side of the turbo.
Old Aug 26, 2015 | 09:19 AM
mattman1234's Avatar
mattman1234
I've done mine ok,but went round the turbo aswell,also did it with about 5 separate pieces.
Old Aug 26, 2015 | 05:03 PM
Caddyshack's Avatar
Caddyshack
I went to zircotec near Oxford. It is permanent and doesn't break down like heat wrap plus heat wrap can cause hot spots if not fully covered or covered in different thicknesses. It isn't cheap but one manifold would be under £200 I think.
Old Aug 26, 2015 | 05:44 PM
mattman1234
Old Aug 26, 2015 | 05:55 PM
frug's Avatar
frug
Sussed it this morning, I think I was just lacking in patience a little yesterday lol.
Managed to get around the whole manifold and around the flange onto the exhaust housing, so once I have the turbo blanket that should be any heat problems sorted, just three stripped holes to sort out in the head and it's ready for going back on and a downpipe making
Old Aug 26, 2015 | 05:58 PM
frug's Avatar
frug
Originally Posted by mattman1234
Bet that thing doesn't hang around matt!
Old Aug 26, 2015 | 06:29 PM
mattman1234
Does go well,when i use it,spends most of the year parked where you see it.
Old Aug 26, 2015 | 06:46 PM
costina's Avatar
costina
Live long and prosper!!
works well we have done a few cars at work.
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
jdsjojo
Aug 30, 2015 07:48 PM
