Why won't my Ford KA 2008 accept the radio code?
Old Aug 22, 2015 | 04:49 PM
Daisychain's Avatar
Daisychain
Unhappy Why won't my Ford KA 2008 accept the radio code?
Hi all, advice needed please:
I visited the Ford showroom this morning who provided me with the radio code, why then, does it not key in.
It states Code: and following the usual, easy instructions to key the numbers in.... Does not work.
Any ideas please.... Thank you
Old Aug 22, 2015 | 05:06 PM
TrevCos's Avatar
TrevCos
What model of stereo is it and how are you trying to enter the code? And did they actually take the stereo out to get the serial number or just quote you the code for what the original stereo should be in the car?
Old Aug 22, 2015 | 05:08 PM
RichieST's Avatar
RichieST
Default Why won't my Ford KA 2008 accept the radio code?
It's not a simple case of punching the numbers in. If code is 2457 for example, press button 1 2 times, button 2 4 times button 3 5 times button 4 7 times. Then it's either button 5 or 6 to enter.
Old Aug 22, 2015 | 05:19 PM
TrevCos's Avatar
TrevCos
As Rich said.
Old Aug 22, 2015 | 07:20 PM
Daisychain's Avatar
Daisychain
Default TrevCos
[QUOTE=TrevCos;6617432]What model of stereo is it and how are you trying to enter the code? And did they actually take the stereo out to get the serial number or just quote you the code for what the original stereo should be in the car?
Hi Trevor, thanks for your message:
The radio was taken out and the serial number was used by the dealership, to find the code.
They put the radio back in but did not key in the code, that was left to me!!!!
The radio is a Ford, model number: 6000AUX
I know how to key the code in, using the method of pressing 1, 2 etc, its just coming up with all Zero's though.
I hope all this makes sense !!
Old Aug 22, 2015 | 07:21 PM
Daisychain's Avatar
Daisychain
Thanks for your message
As with your suggestion, that is how I was attempting to key in the code
This is what I tried to do as you suggested but only comes up with Zero's.
Old Aug 22, 2015 | 07:25 PM
Daisychain's Avatar
Daisychain
Old Aug 22, 2015 | 07:45 PM
focusv8's Avatar
focusv8
Too many attempts?
Old Aug 22, 2015 | 08:12 PM
Daisychain's Avatar
Daisychain
Default Radio
Originally Posted by focusv8
Too many attempts?
Yes, that has occurred, it states 'waiting' then after a while states 'code' again, even on the first attempt, it still won't let me key in the code......all zero's !
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
