Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Focus zetec engine change
Old Aug 20, 2015 | 08:49 PM
da52rkn's Avatar
da52rkn
Default Focus zetec engine change
I recently bought a cheap 1.6 ebony, however it uses colossal volumes of oil, a litre per 100 miles. Other than the car is perfect. Searching the Web I've discovered it's a common problem, due to thrashing from cold. The general advice was the engine is too weak, usually knackered rings. The only viable solution being an engine change. One post said change to a 1.8 or 2.0 lump. I know they look slightly different, the oil filler being the opposite way around for one. How hard is it to change the 1.6 for a 1.8 or 2.0? Not meaning diy wise, meaning practicality. Many thanks
Old Aug 20, 2015 | 09:01 PM
RichieST's Avatar
RichieST
You will need a complete donor car. engine, engine bay and interior loom, exhaust, brakes, suspension, ecu, are all different to name but a few.
The 1.4 / 1.6 is a totally different engine to the 1.8 / 2.0, exhaust and inlets are the other way round for starters!
Old Aug 21, 2015 | 10:59 AM
da52rkn's Avatar
da52rkn
Cheers. Another stupid question, can you use a 1.8 block with a 1.6 head? As the block is the cause of the trouble
Old Aug 21, 2015 | 04:41 PM
RichieST's Avatar
RichieST
No, they are a complete different engine!
JoeyBoyden
Jan 4, 2024 02:36 PM
RUBY123
Oct 22, 2023 12:04 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
track.focus'd
Aug 12, 2015 05:53 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
