Mk3 mfi to efi turbo
Old Aug 12, 2015 | 09:17 PM
EoinXR3's Avatar
EoinXR3
Default Mk3 mfi to efi turbo
Thinking to fit efi on mk3, it has a mfi s1 loom fitted and I have a mk4 efi cabby as a donor.
Do I need to split the efi loom right back to to the ecu and where do I join it in to existing loom?
Can I use the cabby engine and just swop blocks to make it turbo?. I've looked at the sticky but still a bit lost.
Cheers for any help.
Old Aug 12, 2015 | 09:57 PM
simonmcf's Avatar
simonmcf
I think most will say pull out the full s1 loom and fit the efi one. That's what I'm in the process of doing now
Old Aug 12, 2015 | 10:02 PM
EoinXR3's Avatar
EoinXR3
Are you going to fit the mk4 dash or change plugs?
Old Aug 13, 2015 | 06:52 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
If you haven't thought about it and depending on your budget of course it might be easier and more reliable to fit new management, whatever your local/chosen tuner recommends?
Old Aug 13, 2015 | 09:15 PM
moesin2005's Avatar
moesin2005
I done it once a mk4 cab loom into a series one and had to rewire all the stalks
Old Aug 14, 2015 | 06:02 PM
Rob_DOHC's Avatar
Rob_DOHC
If you haven't done so already have a good read through this thread:
https://passionford.com/forum/ford-e...5-04-14-a.html
It will have many answers to questions that you will have.
Swapping looms is fairly straight forward, but whilst the loom is out on the floor its a perfect time to check every thing is in good order and repair if needed.
Rob,
Old Aug 22, 2015 | 08:26 PM
EoinXR3's Avatar
EoinXR3
I decided to fit a base model loom and split the efi loom, I had the wiring all connected and ran lives from battery to the eng man lives and connected earths below wiper motor it ran fine.
Now I've moved the wiring inside the car and have connected lives in to ign live and the earths are connected to drivers speaker well and the two earths from the ecu are earthed to bulk head and I have no spark. Both relays click as do eng sensors when I power them up but no spark. I'm charging the battery just incase its not cranking fast enough.
Should I run all the earths back to battery?
Old Aug 25, 2015 | 12:17 PM
mentalasanything's Avatar
mentalasanything
Good move. When I refurbished my loom I actually made 1 good loom out of 2. The management sub-loom in an XR3i EFi is easily split out once all of the tape is removed.
No need to run the earths to the battery. The only other one to mention is make sure the earth to the EDIS is connected to the body. On an XR3i EFi loom it bolts to the terminal by the horns.
Lee
Old Aug 28, 2015 | 08:43 PM
EoinXR3's Avatar
EoinXR3
Problem was moisture in the amplifier on top of the coil pack if that's what it is, changed it and all good. Hoping to have it all done tomorrow
Old Aug 31, 2015 | 07:52 AM
studabear's Avatar
studabear
Coil suppressor?
Old Sep 7, 2015 | 05:44 AM
EoinXR3's Avatar
EoinXR3
That'll be it, cheers
andyrs1600i
Apr 29, 2026 03:21 PM
Matt Baxter
Sep 16, 2015 08:30 PM
nicos#29
17
Sep 7, 2015 05:32 AM
s1turboman
Aug 29, 2015 04:27 PM
marky_g
Aug 15, 2015 10:43 AM
