ERST S2: Brake shoe fitting kit promblems
Old Aug 6, 2015 | 06:20 PM
Dr. Ickxs's Avatar
Dr. Ickxs
Default ERST S2: Brake shoe fitting kit promblems
Hi,
When I was rebuilding my S2 rear drums, I found out that the brake shoe fitting kit wasn't suited for my brakes...
I noticed that the spring that is connected to the self adjust mechanisme is too short. Also the metal studs thad hold the shoes to the anchor plate are too long.
I re-ordered a fitting kit from ford's, and I still have the same problem....
Ihave theoriginal S2 brakedrums (229mm) and the brakeshoes fit fine.
Anyone else had this problem?
Burtonpower even states that the shoe fitting kit is equal for S1, S2 and all 1.6l mk3 and mk4's......
Please help...
Old Aug 6, 2015 | 07:45 PM
moesin2005's Avatar
moesin2005
the rear drums are unique to the series2 and fitting kits are no longer avalible
Old Aug 8, 2015 | 08:36 AM
haz87's Avatar
haz87
Found the same. All kits advertised dont fit for shit!
Old Aug 9, 2015 | 09:14 AM
Dr. Ickxs's Avatar
Dr. Ickxs
So that's quite @%$# then!
How did you guys solve this? I have used small washers on the back of the anchor plate to reduce the length of the studs...
Would this give me any problems? The studs don't have the conical shape anymore to self align in the holes with the washers.....
thanks for the reply's!
Old Aug 9, 2015 | 03:38 PM
studabear's Avatar
studabear
I wonder would any kits from a sierra or granada be of any use?
Old Aug 15, 2015 | 11:34 AM
marky_g's Avatar
marky_g
Fleet Manager
I think Sierra and grandad are 203mm like same as all other injected escort models
manuel boeckx
13
Oct 3, 2015 02:29 PM
Porplus12
Sep 10, 2015 07:20 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
