Saff front bumper
Other than the side fittings on the bumper, what else secures it to the car?
The 2 box sections that slot in to the chassis, do they have something securing them?
Hi
They only adjust up and down if they are working correctly
I had trouble with one of mine where the captive nut had come loose
Had to tack it back in place with the mig welder (bit at a time so as not to get things too hot)
Needed a bit of freeing with some wd 40 too
Cheers Tim.
Cheers Tim.
Hi Cameron
The rear bumper has a fixing either side
They are plastic turn buttons for want of a better description
There is also two plastic shoes that fit in the body either side that the bumper lugs slide into
The main bumper irons are held in by two torx bolts in the top of the chassis rail in the boot.
There are no rubber inserts in the ends of the chassis rails
You have got height adjusters both sides too.
Cheers Tim.
Cheers Tim.
