What crank pully?? 2ad sump onto 4wd engine?
Got the engine out of my mates Cossie atm.
It's a 4wd car converted to 2wd but still using the 4wd sump, This makes the engine removal a pig as you have to drop the bed to get the engine out so...
I'm looking to fit a 2wd sump - simple!
But....
The 4wd ribbed crank pully that the 4wd runs is a bigger diameter & hits the cps bracket!
Don't want to fit a 2wd pully Aarhus means changing the alternator/waterpump pully & the way it tensions up
Any quick fix for this???
4wd cps bracket???
Or just space the cps bracket away from the pully (as long as cps mounting studs clear the rear of the crank pully???)
But....
4wd cps bracket???
James Porter
Oct 28, 2015 12:17 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
Zoggon
Aug 10, 2015 10:39 AM
