st170 gearbox problem
Old Jul 19, 2015 | 01:03 PM
supersam's Avatar
supersam
Default st170 gearbox problem
driving home last night I went over a sleeping policeman a bit too fast but no more than 30 mph ( I was distracted) subsequently I cannot select 5th gear. all others select though now a little stiff. I have checked and unshipped all the linkages and rods etc (they are all free moving). using the operating rod on top of the gearbox I can select by hand all gears except 5th. I have checked under the car and there is no visible damage as I said it wasn't that fast. Any ideas? as I am stumped and can only surmise that I have broken/bent something inside the box
Old Jul 19, 2015 | 02:24 PM
Fordmad!'s Avatar
Fordmad!
Probably slightly bent the linkage wouldn't take much especially if its stiff in all gears. Wouldn't of thought it would take much of a knock to not be able to select a gear
Old Jul 19, 2015 | 03:59 PM
supersam's Avatar
supersam
yes I was considering that, no damage visible but I may have dislodged a detent or somesuch.
jessie_rs
62
Aug 6, 2019 09:27 PM
dombanks
Sep 21, 2015 08:38 PM
Tank Mike
Sep 10, 2015 07:56 AM
routemaster
Sep 7, 2015 05:27 PM
gingeRS
Sep 4, 2015 06:29 PM
