Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Granada cosworth BOA not starting
Old Jul 19, 2015 | 11:41 AM
Lewisboa24v's Avatar
Lewisboa24v
Default Granada cosworth BOA not starting
Hi picked up a Granada cosworth last night ,
Doner for my 3 door,,
Right she want ran for 5 years ,
Got it turning over ,
But has no spark ,
I have power to coil pack , ,
Lights on dan but won't turn over by key but if I cross starter she turns freely !
Could this be somthing to do with Alarm?? As under dash there is a grey box stamped ford says CONTR ASY LK & ALARM SYS ?
Any help would much appreciated ! Thanks
Old Jul 19, 2015 | 01:05 PM
mk22door's Avatar
mk22door
Fart of the Purniture
As I understand it.. (I had a similar problem once and this is what I was told)
Immobiliser will stop power to fuel pump relay/engine management relay.
Maybe you need to check the wiring at the rear end of the car after checking the relays.
Old Jul 19, 2015 | 07:48 PM
Lewisboa24v
I will have a look and let you no ,
You no witch one is fuel pump relay ???
Old Jul 21, 2015 | 07:58 AM
Lewisboa24v
I got 12v power to cool pack
I got 12v power to ecu pin 1
I got 12v power to ecu pin 37&57
I got 12v power to 3 greens running off edis module (coilpack)
And got 6v to pin 8 on edis module ,
Have got a green an purple relay witch is in bulkhead passenger side , has engine control on it ,
This has only 1 yellow/black wire coming out of it ,
Then runs into passenger side behind dash to green relay. Witch I suspect is fuel relay ??
The green and purple relay in bulkhead was making funny noises yesterday ,,
Aug 14, 2015 07:29 AM
Bloody-Fox
Aug 3, 2015 07:48 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
