2wd front wheel bearings
Old Jul 2, 2015 | 06:29 PM
worm's Avatar
worm
Default 2wd front wheel bearings
hi all i have been restoring my 2wd sapphire cosworth i have replaced the front wheel bearings with fag bearings from matt lewis now with the nut torqued up to 300nm there is still play in the hub and is worse when the wheel is on could i have the wrong bearings? it seems the nut runs out of thread before its tight enough the play is not alot but with the wheel fitted its quite alot any ideas would be great thankyou
Old Jul 3, 2015 | 09:40 AM
Rs5oo's Avatar
Rs5oo
Did the ABS disc engage the splines on the stub. you may need new disc as tightening the nut will have damaged the splines on the stub and the disc
Old Jul 3, 2015 | 05:16 PM
worm's Avatar
worm
hi no the splines are fine they lock in perfect im sure its the bearings it is a straight forward job to do done it before you just cant seem to get the slack out thanks for the reply
Old Jul 3, 2015 | 11:59 PM
jon@work's Avatar
jon@work
If you remove the new bearings and measure their overall thickness, I bet you'll find one or both are only 17mm thick. They both should be 19mm thick. If not, you've been supplied with the wrong bearings.
malkiemac3579
Jul 14, 2017 12:10 PM
Chas
Sep 21, 2015 08:57 PM
cossynut2
Aug 19, 2015 11:29 AM
muz
Aug 1, 2015 06:48 AM
Old ford
Jul 31, 2015 06:50 AM
