Massive spec engine for sale.... 500+hp
House move is forcing sale
Massive spec engine, freshly built and never ran
200 block
10 WRC long studs
Oil spray jets
Lightened and balanced bottom end
Accralite pocketed pistons
Mahle motorsport bearings
SCS big wing sump with wrc breather fittings
7:8:1 compression ratio
WRC head gasket
Kevlar cam belt
Neil Roper head 26/24.5
BD16 inlet cam
BD14 exhaust cam
Double valve springs
New guides
Quaife pulleys
Refurbished cam cover
Genuine rs500 inlet, stripped, cleaned and painted
All linkages and rails plated
8 green injectors
Brand new genuine rs500 fuel regulator
Genuine Garret T4, serviced by cr turbos
ECU with new collins 8 injector board and base map for spec
any questions please ask 07969443979
Superb engine and beautifully detailed.
£9000
Located in somerset
200 block
10 WRC long studs
Oil spray jets
WRC head gasket
Kevlar cam belt
BD16 inlet cam
BD14 exhaust cam
New guides
Quaife pulleys
8 green injectors
£9000
Located in somerset
JoeyBoyden
Jan 4, 2024 02:36 PM
Oct 9, 2015 07:38 PM
rog
Sep 4, 2015 12:10 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
