wheel spacer question on mk4 escort
Jun 26, 2015 | 09:47 AM
I am using the special 'Ghia' wheel bolts (with the wider cup) on my Mk4 Escort with 16" Mondeo alloys. My question is what is the maximum spacer size I can use on the rear whilst still leaving enough thread to bolt up the wheels safely?
Jun 26, 2015 | 10:05 AM
Whatever size spacer you add, add onto bolt length...
Jun 26, 2015 | 10:08 AM
Quote:
Originally Posted by
slammedorion
So you mean I will need longer 'Ghia' bolts?
If so I wasn't aware there were different lengths of this bolt
Jun 26, 2015 | 07:42 PM
Just buy longer wheel bolts for Ford escort...
Get on eBay or a local alloy wheel shop...
Jun 26, 2015 | 08:14 PM
stud and nut conversion using 60mm studs. cheap & easy to use.
Jun 28, 2015 | 03:40 PM
Id go stud and nut all day I'm going to convert to 63mm too
Jun 29, 2015 | 08:26 PM
where can i get the studs and nut from
Jun 29, 2015 | 08:30 PM
I'd have thought Peter Lloyd Rallying sold them to be honest.
It sounds silly but don't forget about the arch to wheel clearance with spacers
Jun 30, 2015 | 10:04 AM
steve.rst
From the world's favourite internet auction website.
Jun 30, 2015 | 01:44 PM
21.75 for the studs on eBay
Vincereese
Jun 1, 2023 09:14 AM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
A.t.p
Aug 15, 2015 11:37 AM
