wheel spacer question on mk4 escort
I am using the special 'Ghia' wheel bolts (with the wider cup) on my Mk4 Escort with 16" Mondeo alloys. My question is what is the maximum spacer size I can use on the rear whilst still leaving enough thread to bolt up the wheels safely?
Cheers |
Whatever size spacer you add, add onto bolt length... :top:
Originally Posted by slammedorion
(Post 6601932)
If so I wasn't aware there were different lengths of this bolt :? |
Just buy longer wheel bolts for Ford escort...
Get on eBay or a local alloy wheel shop... |
stud and nut conversion using 60mm studs. cheap & easy to use.
Id go stud and nut all day I'm going to convert to 63mm too
where can i get the studs and nut from
I'd have thought Peter Lloyd Rallying sold them to be honest.
It sounds silly but don't forget about the arch to wheel clearance with spacers ;). |
Originally Posted by steve.rst
(Post 6602770)
21.75 for the studs on eBay
© 2024 MH Sub I, LLC dba Internet Brands
