Cosworth Coilover options??
Old Jun 22, 2015 | 05:55 PM
adam151082's Avatar
adam151082
Default Cosworth Coilover options??
hi guys im after some new suspension for my cosworth as i want to be able to adjust the ride high as it seems to be sitting low, its currently on Konis.
I have a budget of £500-600 and was after some advice or opinions??
Old Jun 22, 2015 | 06:52 PM
jonfoc's Avatar
jonfoc
Save some more money. £500-£600 won't get you quality items
Old Jun 22, 2015 | 10:25 PM
Hellraiser's Avatar
Hellraiser
Gaz are in your price range, Gaz golds are a little bit more! I got Gaz adjustables on, I paid £500 n can't fault em mate lot better than the koni' s I had on before
Old Jun 24, 2015 | 05:10 PM
adam151082's Avatar
adam151082
thanks guys
anyone else got a opnion?
Old Jun 24, 2015 | 08:33 PM
doga-ot's Avatar
doga-ot
Personally i'd have KW coilovers
Old Jun 24, 2015 | 08:38 PM
costina's Avatar
costina
Live long and prosper!!
Originally Posted by adam151082
thanks guys
yeah don't waste your money unless its a track car. Good quality ahmed springs and koni shocks will be fine.
been there done that wasted money.
quality coilovers will cost over a grand and will require a full set up and corner weighting.
Old Jun 25, 2015 | 04:40 PM
adam151082's Avatar
adam151082
I have Konis atm but i want adjustablity, hence the Coilovers.
Old Jun 25, 2015 | 08:09 PM
IainRS1700T's Avatar
IainRS1700T
Harsh but fair.
Ultimately coil overs can do what ever you want them to do; damping, rebound, spring rate etc.
Unfortunately the budget end of the market tend to be less well resolved both in terms of performance across a spectrum of uses (road, track etc), and also despite looking great when new tend to deteriorate fairly quickly and not wear so well as better crafted (and more expensive) items.
Buy right, buy once (or words to that effect) but it will be comfortably double your budget.
That said, the good stuff retains it's value for that reason and is also eminently serviceable, so if you need to sell them on there's always a market for them.
Right now that looking for a used set could be an option for you? But if so, to limit more expenditure try to aim for stuff which has had a service, or calibration recently so you know they're still performing as they should.
Iain
Old Jun 25, 2015 | 08:54 PM
jonfoc's Avatar
jonfoc
Originally Posted by IainRS1700T
Harsh but fair.
Iain
Very wise words. I work at leda, we see a lot of budget dampers brought to us for a check and dyno. Few if any match or give the spec required. Gaz seem to be getting a lot better these days, try and get a set of golds if you go that route. They have a better adjuster knob.
Old Jul 1, 2015 | 08:52 PM
adam151082's Avatar
adam151082
Can you get discount on Leda's
Old Jul 1, 2015 | 09:08 PM
jonfoc's Avatar
jonfoc
Yes but not to your budget sadly mate
Old Jul 1, 2015 | 10:26 PM
james kiely's Avatar
james kiely
jonfoc
how much would i be looking at spending to buy a decent leda coilover setup for a mk3 escort track car mate ?
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
adam151082
Aug 30, 2015 08:34 AM
Aug 14, 2015 07:29 AM
adam151082
Aug 11, 2015 04:50 PM
