Bailey oil breather
Old Jun 9, 2015 | 03:05 PM
johnboy73's Avatar
johnboy73
Default Bailey oil breather
ive just bought a 2nd hand Bailey oil breather but have no fitting kit or much idea of how to fit it!can anyone give me help as to how to fit it and what bits I need?i know that both sides of the rocker plumb in to it but what happens to the odd looking unit on the left hand side of the rocker with the plastic pipes coming out of it????help,please!!!!!
Old Jun 9, 2015 | 04:48 PM
Chopshop85's Avatar
Chopshop85
The odd looking unit is the stock breather, so that comes off.
Then you need pipes going from the two rocker breathers into the top two inlets on the bailey.
Then the two pipes on the bottom of the bailey breather are return to sump and the metering unit.
(remember to use oil hose as other rubber/silicone hoses with perish)
Old Jun 10, 2015 | 10:40 AM
johnboy73's Avatar
johnboy73
What about the plastic hoses on the stock breather?do you block them off?
Old Jun 10, 2015 | 11:21 AM
johnboy73's Avatar
johnboy73
Just a bit unsure of what to do.
Old Jun 10, 2015 | 12:37 PM
Chopshop85's Avatar
Chopshop85
They all need to be removed as the bailey breather sits the other side of the head.
Old Jun 10, 2015 | 01:59 PM
johnboy73's Avatar
johnboy73
Ok,I'll give it a go.thanks for your help,much appreciated!
Old Jun 10, 2015 | 11:55 PM
Chas's Avatar
Chas
From what I have seen one of the breathers will need blocking off running from the inlet manifold the crankcase breather.
What injection system are you running? MFI or EFI?
Here is what mine looks like. The breather could do with repositioning but I have left it for now.
Old Jun 11, 2015 | 12:00 PM
johnboy73's Avatar
johnboy73
I'm running mfi mate.
Old Jun 12, 2015 | 06:28 PM
Chas's Avatar
Chas
If that is the case it would be best for you to block off the thinner pipe from the top of the inlet manifold running to the breather or to plumb it into a boost gauge if you have one .
In the Bailey setup this top thin pipe is not used.
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
