Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Ford Key Fob Sticking On Lock Door
Old Jun 2, 2015 | 02:05 PM
jonnycool's Avatar
jonnycool
Default Ford Key Fob Sticking On Lock Door
Hi All,
I have one of the keys below shown in this image:-
The lock button is sticking and won’t allow me to open the car most of the time.
I have opened it up and the switch on the PCB is stuck down and doesn’t click like the others.
What is the cheapest and easiest way of getting this working again.
Can I just by a whole new PCB will this work?
Thanks
JON
Old Jun 2, 2015 | 02:36 PM
STeve's Avatar
Super Moderator
just get another 2nd hand keyfob as the coded part is in the casing
Old Jun 2, 2015 | 06:18 PM
jonnycool's Avatar
jonnycool
Ok so after i have purchased the working second hand key which bits do i need to get this working again.
Old Jun 4, 2015 | 12:16 PM
dubzza's Avatar
dubzza
Falling in love with Ford
I've just bought a new key on ebay for £2/3, it comes with an empty bit to stick your pcb into, and an uncut key. Still need to find somewhere that will cut old ford keys tho. If you're pcb is knackered probably gonna be looking at a lot more money for a new one and getting it all coded
Old Jun 5, 2015 | 08:05 AM
jonnycool's Avatar
jonnycool
I have totally broke the button off the PCB now i tried to get the metal case off but ended up pulling the button off all together.
Looks a little like the image below now:-
So the question is can i buy another PCB and slot it in ?
Or
Can i buy a second hand key and put the PCB in my key from that one ?
Any hits and tips welcome
Old Jun 5, 2015 | 08:39 AM
dubzza's Avatar
dubzza
Not 100% but I think you'll be looking at a bit of money to get it programmed unless you can use your main key to program the new one yourself
Old Jun 5, 2015 | 09:00 AM
jonnycool's Avatar
jonnycool
This is getting complicated.
JoeyBoyden
Jan 4, 2024 02:36 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
track.focus'd
Aug 12, 2015 05:53 PM
tankybaby66
Aug 9, 2015 07:13 AM
