BOA starter with type 9
Old Jun 1, 2015 | 08:11 PM
kevchard's Avatar
kevchard
Default BOA starter with type 9
Hi
Which starter motor do i need with a 2.9 V6 24v cossie lump with a 3 bolt type 9 bellhousing please?
The Granada cossie with auto box had a 2 bolt starter on.
I have bought an xr4i starter with 3 bolt holes, but they are not in the right place by a fair bit. Is there a difference between 2.0 xr4i starter and 2.8 please?
Kevin
Old Jun 1, 2015 | 08:36 PM
doga-ot's Avatar
doga-ot
Originally Posted by kevchard
Hi
Kevin
u need a 2.8 or 2.9 starter from an xr4i or xr4x4!
2.0 xr4i ar 4pot engines yours is 6pot same as the above, even a 2.8/2.9 Granada/capri starter will work as long as its 3 hole
Old Jun 1, 2015 | 08:53 PM
kevchard's Avatar
kevchard
Brilliant thank you.
Does it matter what year?
Kevin
Old Jun 1, 2015 | 09:14 PM
v6gerry's Avatar
v6gerry
Hi Kev what flywheel are you using ?
Old Jun 1, 2015 | 09:15 PM
doga-ot's Avatar
doga-ot
Kevin
Nope, quick question do you already have a fucked starter? if so you can just strip it down and use the motor from the other one its piss easy that's what I do on my saph BOA/Mt75
Old Jun 2, 2015 | 07:13 AM
kevchard's Avatar
kevchard
Hi Gerry, Nice to hear from you
It is the 2.9 flywheel i think, but only difference between that and the 2.8 is the thickness isn't it?
Hi Wes
Yes we have a knackered one that fits fine, a company has looked over it to re con it, but there arent any good bits on it eg solenoid knackered, windings shot, bearings rusted :-(
What starter would you use out of curiousity though if we could cut and shut a healthy motor onto my existing 'nose' piece?
Kevin
Old Jun 2, 2015 | 08:27 PM
doga-ot's Avatar
doga-ot
Hi Wes
Kevin
I have a Boa with 2.8 flywheel and mt75 gearbox my box is the later box 3 hole starter and finding a starter was a pain cos i got 2.8flywheel i needed starter with less teeth think theyre 7 and 9 all 7 teeth starters were 2bolt so i just took it apart and put it in the 3bolt starter shell all good ive done a few!
Old Jun 3, 2015 | 09:06 AM
kevchard's Avatar
kevchard
Cheers. Hopefully i wont have to fit a crank handle to the front pulley to start it then
Kevin
Old Jun 3, 2015 | 01:49 PM
doga-ot's Avatar
doga-ot
Kevin
Rofl 👍
Old Jun 3, 2015 | 02:03 PM
kevchard's Avatar
kevchard
Don't 2.8 & 2.9 have same diameter flywheel and number of teeth, just the 2.8 is thinner and lighter?
Kevin
Old Jun 4, 2015 | 02:14 PM
doga-ot's Avatar
doga-ot
Kevin
Dnt think so yh theyre thinner but teeth re diff it dnt matter to much!
Old Jun 5, 2015 | 06:43 PM
kevchard's Avatar
kevchard
Hi Wes
Thank you for the help, we have used the healthy motor & solenoid from the autobox (2 bolt starter) and the flange from the 3 bolt motor - hey presto as you suggested we have a working cut/shut starter
Cheers for the advice, it has cost nothing to get a working unit.
Kevin
Old Jun 5, 2015 | 07:59 PM
doga-ot's Avatar
doga-ot
Cool bud and hey look complicated after many fuxk arounds by people trying to get a starter for mine 1 day just took 2 apart to see if i could make 1 couldnt believe how easy it was since then always do my own even alternators can be done a little bit of pain in the arse though
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
