Hand brake light on
Old May 30, 2015 | 09:49 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Default Hand brake light on
the mondeos handbrake light is flashing randomly while driving so what could this be a symptom of?
Does it do anything other than tell you the hand brakes on? On the Sierra it was a low fluid warning light and abs pressure etc so rather than just change the switch is rather have a proper fix
It comes on for a second or so, flashes a few times then out again
Or it will come of for a few seconds and then go out
All while driving on smooth roads and not after bumps or the like
If it was any other light I'd wait till I got home but obv brakes are the one thing you can't ignore
Old May 30, 2015 | 10:01 AM
martysmartie's Avatar
martysmartie
Yes, it is multiple purpose, have you checked the fluid?
Martin
Old May 30, 2015 | 11:10 AM
dojj's Avatar
dojj
That was my first thing but it's all up to the level
Old May 30, 2015 | 12:07 PM
Check to see if the adjustment on the hand brake lever.
Old May 30, 2015 | 04:00 PM
dojj's Avatar
dojj
The handbrake needs 2 inches of movement before the light comes on so I can't believe it's the switch
Old May 30, 2015 | 05:15 PM
t230's Avatar
t230
dunno if focus w reg same but ive got prob with my pads and my handbrake light comes on as well...this also happened when my rear caliper failed...
Old May 30, 2015 | 08:10 PM
Could be a faulty switch in the resivor.
Old May 31, 2015 | 12:43 PM
dojj's Avatar
dojj
Good thinking batman but I'm going to try things next weekend now starting with the switch and fluid for the obvious stuff
Old May 31, 2015 | 05:08 PM
It's probably not the same but fiat punts had a fault with the brake warning light on and it was air in the resivor. I used to give them a tap to get the air out.
Old May 31, 2015 | 05:30 PM
dojj's Avatar
dojj
I've got some fluid and copper grease now so when the time comes I'll figure out how to get the wheels off and go from there
If I didn't need to access the bleed nipples on the other side of the caliper is so it from within the spokes and not even need a jack
Old May 31, 2015 | 05:31 PM
RichieST's Avatar
RichieST
Unplug the wiring plug on the reservoir cap, see if it still does it.
Old Jun 1, 2015 | 04:53 AM
dojj's Avatar
dojj
It did it about 4 times in 2 hours totally at random but seeing as the cars going to be parked up for the next few weeks I'm not sure I'll get a chance to look at it
Old Jun 1, 2015 | 08:00 AM
doga-ot's Avatar
doga-ot
Right dojj ii had it on my fez fords said its 1 of 3 things:
1.faulty handbrake switch (unlikely)
2.brake fluid below max (most likely)
3.rear abs s nsors/rings all shitted up
Old Jun 2, 2015 | 07:16 AM
dojj's Avatar
dojj
Yesterday in the rain I decided to have a look
Other than the rear brakes being almost rusted solid into place the off side bleed nipple was leaking slightly
So a full rear refurb and a replacement nipple from my stack of parts and a fluid top up means it should all be sorted now
And the level is difficult to gauge as its a bit deceiving
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
