Fiesta Turbo-No spark
Old May 16, 2015 | 11:17 PM
James Porter's Avatar
James Porter
Default Fiesta Turbo-No spark
Picked up a Fiesta turbo today that's been stood for 8 years.
Put a new battery on it, fresh fuel & checked oil etc.
Turns over fine & fuel pump is priming but no spark. I've checked wiring plugs around the coil pack, checked fuses & all seems good.
I've never had any issues like this with a fiesta before so not sure if there's anything obvious I should be checking?
I also took the plugs out & gave them a clean.
I'm not great when it comes to electrical issues, I'm also inpatient so any help would be good
Old May 16, 2015 | 11:21 PM
Billy_RS's Avatar
Billy_RS
Check the edis module mate. A mate of mine had the same problem and that was the fault
Old May 17, 2015 | 06:54 AM
grant_xr's Avatar
grant_xr
crank sensor/wiring?
Old May 17, 2015 | 06:56 AM
James Porter
Visually checked it but think replacing that first might be a good idea
Old May 17, 2015 | 01:30 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I had issues where mine would trigger the pump but wouldnt trigger the edis to fire the coils, try'd it with a jump and it turned over that bit faster and worked, so new battery...may be worth a try
Old May 18, 2015 | 02:05 PM
James Porter
So I've replaced the edis, coil pack & crank sensor but still no spark.
Can you bypass these like the escorts?
I mean like a live from the battery to the coil trick on the mfi's ?
Old May 18, 2015 | 02:31 PM
James Porter
Sorted!
Found this, started straight up!
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
