I wanna cry!!!!!
Old May 16, 2015 | 08:14 AM
JFX's Avatar
JFX
Default I wanna cry!!!!!
Good Morning All, firstly let me introduced myself as Zoé the proud owner of my 54 plate Fiesta ST which I adore but she's poorly and I don't know how to fix!!!
I've read various posts already and apologies if it's in the wrong section and/or being covered elsewhere I just need advice.
Currently when coming to a stand still at lights or junctions the revs increase upto 2k but after 30 seconds of hunting drops to approx 1300rpm which to me is still high.
It's been into the garage which I was first told it was an air leak somewhere, then it was the throttle body. My throttle body has been cleaned but it made it worse and then I got a second hand one of my mate. This was put on yesterday and again it's made no difference.
PLEASE PLEASE PLEASE can anyone give me any tips on what I can do next.....
Thank you so much for any repsonse
Zoé x
Old May 16, 2015 | 08:17 AM
Cant help you with the problem but hi zoe.
Old May 16, 2015 | 10:27 AM
lacey's Avatar
lacey
Do they have a idle control valve of some sort ?
Old May 16, 2015 | 11:12 AM
Oranoco's Avatar
Oranoco
Isn't this the Mondeo engined car? In which case I would be looking to the PCV pipe under the inlet as this can crack and cause the symptoms you describe.
Old May 16, 2015 | 12:13 PM
Churtz's Avatar
Churtz
As above.... pcv hose splits or valve fails and causes this. I would check first.
Where are you based? (I'm on my phone and it doesn't show location)
Matt.
Old May 16, 2015 | 02:42 PM
JFX's Avatar
JFX
Thanks for the Welcome Glenn.
From what I've read the Fiesta Mk6 ST doesn't have a ICV
The PCV seems to be being mentioned quite a lot so it could be an air leak from there but I would have thought the garage would have checked this.
Churtz - I'm up near Sheffield
I've read that the ECU could need an update as I would say that the car hasn't really been looked after that well.
Really wish I knew how to take it to piece and figure it myself as I hate relying on others to fix
Thanks everyone for your input
Zoé x
Old May 16, 2015 | 03:37 PM
Sinbad's Avatar
Sinbad
Nobles Motorsport is only just down the road from you in Chesterfield, plus he's got a rolling road to give him real road driving fault help
Old May 16, 2015 | 03:43 PM
sridgett's Avatar
sridgett
The only way is dagenham
Welcome zoé, sorry to hear about your car, on most old skool cars you can adjust the tickover, but on a moden fiesta I wouldn't like to say, sorry to not be able to help.
Old May 16, 2015 | 03:55 PM
sridgett's Avatar
sridgett
Just thought, if you was to buy a Haynes manual for it would it not tell you in there?
Old May 16, 2015 | 07:08 PM
DangerousBryan's Avatar
DangerousBryan
The breather pipe under the inlet manifold is prone to splitting on the 1.8/2.0's. I'm in Sheffield and can have a look tomorrow if you can get it to me?
Old May 21, 2015 | 05:26 PM
JFX's Avatar
JFX
Well its been into Ford today and the inlet pipe was the problem - thank you for all your help guys I really do appreciate it xx
Mc5506
Oct 5, 2015 09:57 PM
turbochild
13
Oct 1, 2015 05:33 AM
Fil
Sep 30, 2015 12:08 PM
