Tap size for AN6 fitting?
Old May 15, 2015 | 06:58 PM
muz's Avatar
muz
Wye Valley Hardcore
Default Tap size for AN6 fitting?
Am I right in thinking an AN6 fitting uses uses an M14x1.5 thread?
Reason is the handy drain plug someone added to the bottom of my gearbox is leaking and when I investigated the threads have been stripped and the adapter chemical metaled in.
I've sized up an AN6 to AN6 male/male adaptor and it's slightly too big for the hole which is 12mm so I should be able to run a tap straight through it providing M14x1.5 is correct.
Anyone know for sure as my tap set only goes up to M12 so I have to go buy one.
Old May 15, 2015 | 07:17 PM
lacey's Avatar
lacey
There not metric
I may be wrong with out looking but I think it -6 = 7/16 unf or unc
Google it mate it should not be hard to find
Old May 15, 2015 | 07:47 PM
muz's Avatar
muz
Wye Valley Hardcore
Originally Posted by lacey
There not metric
Cheers, mate. I was thinking they were metric! Apparently it's a 9/16-18 UNF which is 14.2 mm so I wasn't far off
Old May 15, 2015 | 08:50 PM
jonfoc's Avatar
jonfoc
9/16 unf according to earls website mate
Old May 16, 2015 | 10:47 AM
stevieturbo's Avatar
stevieturbo
C**t
Does it seal on a taper or against a flat surface ?
ie is there any need to use an oddball thread like -6 ?
Old May 16, 2015 | 02:35 PM
muz's Avatar
muz
Wye Valley Hardcore
Flat surface.
Only reason I was going to use -6 is because I have a few left over o-ringed -6 male/male adapters and hose fittings and end caps.
Old May 16, 2015 | 03:19 PM
stevieturbo
C**t
Would do rightly then
borboyous
Aug 22, 2015 11:17 AM
RockinRein
Aug 19, 2015 07:08 PM
M K
Aug 12, 2015 06:57 PM
Perfmr2
Aug 6, 2015 07:30 AM
