Rusty brakes question
Old May 12, 2015 | 08:29 PM
VickyV's Avatar
VickyV
Hi, its me!
10 Year Member
Default Rusty brakes question
Im picking up my StreetKa at weekend and it has been stood outside since last September without moving.
I noticed that the front brakes are rusty, will this just come off as I drive or will I need to get them changed?
Thanks
V. x
Old May 12, 2015 | 08:31 PM
RichieST's Avatar
RichieST
Driving will clean the surface rust off them, I would inspect them afterwards and if they are badly pitted then they are an MOT failure and will want changing.
Old May 12, 2015 | 08:34 PM
VickyV's Avatar
VickyV
Hi, its me!
10 Year Member
Thanks, I was a bit worried about driving like that but thought it might rub off.
I only have to drive just over a mile to get it back home.
As the car is free I'm expecting to spend a bit of money on it to make it nice again
V. x
Old May 12, 2015 | 08:53 PM
bigjohn0's Avatar
bigjohn0
Lets just hope the handbrake has not been on all that time otherwise its going nowhere.
Old May 12, 2015 | 08:55 PM
VickyV's Avatar
VickyV
Hi, its me!
10 Year Member
It might have! worried now
Old May 12, 2015 | 09:11 PM
bigjohn0's Avatar
bigjohn0
If it has then you need to take the Alloys off and give the brake drums a good smack with a hammer to free them off and if that don't work its a strip down.
Old May 12, 2015 | 09:14 PM
VickyV's Avatar
VickyV
Hi, its me!
10 Year Member
Yes, just been reading about them... Ill take someone strong with me!
Old May 13, 2015 | 06:26 AM
STeve's Avatar
Super Moderator
at least discs are cheap for these cars should it need them, but hopefully it will just need driving a bit to scrub the rust off, as for rear brake should it be stuck just rock the car back and forth and it may well free them off then get someone to service them up once home
Old May 13, 2015 | 07:41 AM
strada84's Avatar
strada84
Brakes can have surface rust on them after standing as little as 24 hours depending on conditions.
They'll be ok to drive a short distance, but for the cost and peace of mind, I'd probably fit fresh on there whatever condition they're in.
Whereabouts in Staffordshire are you?
Old May 13, 2015 | 08:39 AM
alistairolsen's Avatar
alistairolsen
If theyve been sat for 6 months, I'd drive it carefull home and then bin them for all the cost involved, I wouldnt want to trust the fins, they will be pitted and lumpy where the pads have held water against the disks too most likely and after scrubbing all the rust off, I'd want to swap the pads anyway.
You can probably get OEM disks and pads for ~£50 I'd imagine.
Old May 17, 2015 | 07:34 PM
VickyV's Avatar
VickyV
Hi, its me!
10 Year Member
Well,
I picked the Ford StreetKa up today and even though it had been sat with the handbrake on since last year... It was fine. the handbrake worked as it should and the brake discs are now shiny again
Old May 18, 2015 | 11:59 AM
STeve's Avatar
Super Moderator
nice one vicky looks like the ford gods were smiling on you
Old May 18, 2015 | 05:02 PM
Caddyshack's Avatar
Caddyshack
Probably worth a brake fluid and engine oil change though if been sitting around
Old May 18, 2015 | 06:30 PM
Oranoco's Avatar
Oranoco
Strongly agree with this.
Old May 18, 2015 | 07:48 PM
cossiestu's Avatar
cossiestu
Your lucky, mine sat in the garage without the handbrake on and it still seizes up!?
Prickly_buzz
Dec 7, 2017 09:52 PM
155lee
Oct 27, 2015 04:55 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
focus2351
Sep 9, 2015 09:33 PM
