Emptying the Fuel Tank
Old May 11, 2015 | 07:27 AM
auralisRS's Avatar
auralisRS
Default Emptying the Fuel Tank
Hi guys.
I need to empty the tank on the car as fuel has been in there since 2008. There is barely any in there, fuel rail feed is disconnected, so thought about shorting the pins on the Fuel relay...can anyone help me as to its location and number. Its a 1996 St Escort.
I tried siphoning, but there is an mesh halfway down the filler neck, so Im stuck as to what to do now, anyone done this before.
Many thanks
Old May 11, 2015 | 07:47 AM
cossiestu's Avatar
cossiestu
If there is only a tiny bit left in there, if you were to brim fill it with fresh petrol, surely it would be ok?
Old May 11, 2015 | 08:16 AM
auralisRS's Avatar
auralisRS
Hi, thanks for your reply. Unfortunately the car is off the road and will remain so -the fresh fuel is just to get it restarted and hopefully run her every few weeks, a new tank full would just put me in the same situation as time goes by as it will never get used.
Old May 11, 2015 | 08:00 PM
cozzzzy power's Avatar
cozzzzy power
hi pal its relay 9 brown one, or you could split the wire connector at rear of car, if you look up between rear bumper and the back panel you can see the pump and sender wires, its the two thicker ones you need, disconnect the plug and put a live and earth to them and the pump will run, black/red needs to be live cheers
Old May 11, 2015 | 08:54 PM
auralisRS's Avatar
auralisRS
Thats a brilliant idea...I think thats the way I'll go. Many thanks
Old Jun 14, 2015 | 09:10 PM
Cossy Mike's Avatar
Cossy Mike
Can you not just pull the pipe off the tank before it goes into the pump?
Old Jun 15, 2015 | 09:16 AM
dojj's Avatar
dojj
Resident Wrestling Legend
if it's anything like the sierra loom there will be a bunch of wires going to the boot spare wheel well with a connector along the way somewhere under the rear seats
i used this to spin the pump up to drain the fuel when ever i've had to do this in the past
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
mpilk
Sep 27, 2015 09:21 AM
