Anyone rate vibra technics
I fitted a pair on vibrant tech engine mounts and they have been spot on. It sounds daft but the engine felt more responsive. My standard mounts were well fooled though.
Ah I see! As my bottom one went I thought I get em all replaced! Soon as boost kicks in it tourqe steers like a mofo :s
It caused to exhaust hanger to jump off the rubbers behind the box
rapid ford is where I have always got my mounts from and Dan is a member on here
http://www.rapidford.co.uk/index.php
edit just saw what car you have and I also had a FRST which split both mounts so once the cradle was lowered the OE mounts were in 2 parts and fell out and I replaced with VT ones
Do I just drop the cradle and bolt new mount to that?
