Cossie PF09 tps
Old May 10, 2015 | 05:54 PM
rsbondy's Avatar
rsbondy
Default Cossie PF09 tps
Hi can any one point me in the right direction I'm struggling to source a pf09 tps....... This is not a wanted add, it's more of a need add lol. Cheers
Old May 10, 2015 | 07:10 PM
Cossy Mike's Avatar
Cossy Mike
Not much help but look for ducati PF09's as well, they the same
Old May 10, 2015 | 08:20 PM
rsbondy's Avatar
rsbondy
Are these the same sensor?
Old May 10, 2015 | 08:31 PM
Cossy Mike's Avatar
Cossy Mike
yes...
keep looking for a cheap spare myself
Old May 13, 2015 | 07:09 PM
mattman1234's Avatar
mattman1234
there not the same,they look the same but they are not linear,as i found out
Old May 14, 2015 | 03:37 AM
2wd's Avatar
2wd
... So are there another alternative to the "Ford PF09" ... ???
Old May 14, 2015 | 06:08 AM
Zoggon's Avatar
Zoggon
How about
fiat coupe 16v turbo
fiat tempra, tipo 1.8, 2.0
alfa romeo 155, 33
lancia delta, dedra 1.8, 2.0 ?
I don't know if theres a difference between PF09/05, PF09/04 or red PF09?
Fiat Tipo Throttle body 87-95
Old May 14, 2015 | 10:12 AM
cossynut2's Avatar
cossynut2
10 Year Member
When I changed my L6 ecu to a L8 ecu on my 2wd I got a secondhand one and it has been no problem. They are a robust item which rarely go wrong, try the Cosworth breakers.
Old May 14, 2015 | 11:36 AM
jamie956's Avatar
jamie956
There a guy called Clint gaskin who now makes a connector that converts a PF01 in to a PF09 for Ł25 so no need to change, he trades unrder brands hatch performance or look for him on FB.
Old May 14, 2015 | 01:17 PM
jon@work's Avatar
jon@work
If, say, changing from a L6 to an L8 ECU, you need to change the TPS and the wiring. The loom on ebay addresses the wiring only.
Old May 14, 2015 | 01:28 PM
jamie956's Avatar
jamie956
This is not a wiring change over loom, it has a PCB to convert the voltage.
Old May 14, 2015 | 05:38 PM
2wd's Avatar
2wd
Originally Posted by Zoggon
How about
alfa romeo 155, 33
Sounds interesting...anyone knows about these ???
Old May 14, 2015 | 07:20 PM
jamie's's Avatar
jamie's
Where abouts are you?
I may know somewhere local you can get 1
Old May 15, 2015 | 11:30 AM
2wd's Avatar
2wd
If you're asking me, I'm just on the other side of the sea...in Denmark
But still I need to find out about this as I suspect that I have a problem with my TPS
Old May 15, 2015 | 04:27 PM
jamie's's Avatar
jamie's
Was asking the original poster mate
Old May 15, 2015 | 04:39 PM
slider's Avatar
slider
Clints lead is just a swap of lead to save you from having to open the plug up and swap pins, very usefull but it does not contain any form of chip,
you can use a pf01 switch still, swap the wires and then all you need to do is move the switch slightly so that it has passed the cut off part, out a volt meter on the back of the ecu plug and test for 5v when the throttle is closed.
the reason for this is that the pf01 has a break in the internal resistor board that at idle on a L6 or L1 ecu shows a high resistance of about 5k ohms that the L8 does not like as it sees it as a fault
Old May 15, 2015 | 04:51 PM
jamie956's Avatar
jamie956
Its not a pin swap lead as said before,
Taken from his FB post
''I have a new lead that converts a PF01 Throttle Sensor into a PF09 so when you fit a L8 or P8 to a 2wd Engine you don't have to do buy an expensive PF09 or swap any wiring about. I have been testing this for a few months now and originally made up a batch of 10 cables for testing, I am going to give the ok to produce more this week but if anyone wants one of the 6 test cables I have left I will do them for Ł25 each.''
Old May 16, 2015 | 09:37 AM
2wd's Avatar
2wd
Ok ...
Old May 17, 2015 | 09:54 PM
markk's Avatar
markk
Heres one
http://www.ebay.co.uk/itm/Cosworth-Y...e=STRK:MESE:IT
Old May 18, 2015 | 07:50 AM
cossynut2's Avatar
cossynut2
10 Year Member
Originally Posted by markk
He needs to get it asap, good price as well.
Old May 18, 2015 | 12:05 PM
rsbondy's Avatar
rsbondy
Got one guys, may also have another as a spare. Cheers for the replys
Old May 18, 2015 | 12:26 PM
2wd's Avatar
2wd
Where did you get them ...and are they OE ford parts or is it some of the above mentioned ...?
DixieTheKid
11
Jun 6, 2020 11:20 AM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
