turning up the boost
Old Apr 3, 2005 | 03:03 PM
fireblade's Avatar
fireblade
Default turning up the boost
hi folks just bought a 1990 s2,its got scorpion exhaust,k+n,front mount intercooler,new engine
the ecu is chipped,but is only running 8psi
how do i turn the boost up and to what safe level
do i have to turn fuel pressure,
any help or advise
Old Apr 3, 2005 | 03:28 PM
320 bhp's Avatar
320 bhp
U TURN THE BOOST UP BE SHORTING THE ROD ON THE ACTUATOR (TURN IT) BUT WOULD RECOMEND IT TAKE IT AND GET IT TUNED ON A ROLLING ROAD THEY WILL DO IT ALL FOR YA SAVES U BLOWING YA ENGINE
Old Apr 3, 2005 | 03:42 PM
zvhrst's Avatar
zvhrst
same as 320 says,
or if ya want a bit more by a bleed valve and turn up to no more than 11-12 psi @most without a rollin road session
Old Apr 3, 2005 | 03:54 PM
RSKieron's Avatar
RSKieron
Don't whack it up blindly - best leave it as it is and get down to a tuners to get it done properly....
Old Apr 3, 2005 | 07:49 PM
DazC's Avatar
DazC
It will need setting up by a reputable tuner otherwise you risk loosing your pistons in a big molten mess of aluminium....
Old Apr 4, 2005 | 09:27 PM
Rick's Avatar
Rick
Hey mate, cheers for today
Clean car u got there - give Stu a call about a setup - wrekon she'll go well
Old Apr 4, 2005 | 09:41 PM
bbsheppo's Avatar
bbsheppo
Fireblade, sorry for being cheeky but where did you get it from?
Old Apr 5, 2005 | 06:22 AM
fireblade's Avatar
fireblade
Default rs
got it off lee reynolds from yorkshire off this site
pics are here somewhere
Old Apr 5, 2005 | 08:39 AM
Rick's Avatar
Rick
kin ell - KNEW i knew that car lol
Nice car
Old Apr 5, 2005 | 02:15 PM
db's Avatar
db
Best to find out what chip is in the ECU, this is the way to find out what boost the car could run and go to a tuner and have it set up properly.
Apart from that you could consider to mount a lambda sensor in the exhaust and wire up a air fuel gauge. Than you always know the mixture.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
