COSWORTH WATER PUMP
AS ABOVE I HAVE JUST FITTED A 200 BLOCK INTO MY 2WD COSSIE WHICH WATER PUMP WILL I HAVE TOO USE
AND IS THERE ANY MORE THINGS I WILL HAVE TOO CHANGE
CHEERS BARNEY
CHEERS BARNEY
AFAIK you can run either 2wd or 4wd pump, but use the appropriate thermostat housing for the pump you choose, although this will probably be dictated by which head you have, as the thermo housing fixings are different.
I suspect it'll be easier to use a 2wd pump if you have a 2wd head and thermostat housing (and a LOT cheaper
Oct 9, 2015 07:38 PM
Aug 14, 2015 07:29 AM
