T5 speedo drive
Anyone know where these are available from? My speedo has been a bit twitchy lately and stopped working earlier. The cable seems ok so I'm presuming it's the drive in the gearbox worn
I thought my speedo drive was gone too cos I had no speedo on the clocks. Replaced the cable, same thing. Checked the speedo drive and it was good!, after me spending close on Ł100 for a spare!! Turns out the plastic gear on the main shaft inside the box, has feckin disintegrated
I managed to source another box which I got for cheap, that was some balls too cos they're so so bloody expensive and are close on 30 years old!I'm swapping the box in a few weeks so hopefully it'll work.
Hope you can find one matey
Philip.
For the plastic gear bit these are available in USA for numerous Tremec boxes and not expensive. I've bought a few for my Tremec box, and I think IIRC there are numerous product no's for different types of boxes. Mine looks identical to a T5 one save the little nose bit is a bit longer, but nothing a sharp knife or hacksaw wouldn't fix.
They're peanuts in the states. Colour coded according to the no. of teeth if you're messing around with wheel size etc.
SMILER258
Sep 28, 2015 09:04 AM
