4x4 saph boost miss fire problem
Old May 2, 2015 | 05:37 PM
mrmann's Avatar
mrmann
Default 4x4 saph boost miss fire problem
advise needed... my 1992 4x4 saph has a slight miss fire when in boost. at around 3500-4000 rpm its hesitates slightly. if you bring the car up to boost gently its happens less. the car is totally standard apart from a 4" scorpion exhaust. Its happens more if the fuel is low(1/4 tank).
so far all ive tried is new plugs. was advised to use 071 plugs gaped at 0.9 to 1.05. these made the car run lumpy so took them out. ive been advised to try new ht leads... Can anyone recommend a brand?
Any other hints/tips welcome
Old May 2, 2015 | 05:39 PM
Jay,'s Avatar
Jay,
Sponsor
Gap the plugs at .65 that should help
Old May 2, 2015 | 05:42 PM
mrmann's Avatar
mrmann
i'll give that a try
Old May 2, 2015 | 06:19 PM
mat_rss2's Avatar
mat_rss2
Had the same problem and was the plugs, boost was blowing the spark out
Old May 2, 2015 | 06:28 PM
Jay,'s Avatar
Jay,
Sponsor
ok is the rev counter jumping about ?
is the dizzy and phase sense set up properly
On the engine loom are the 3 plug still left on it on the bulkhead above the cam cover ? if so they might need removing check the one nearest the drivers side for corrosion
Old May 4, 2015 | 09:00 PM
mrmann's Avatar
mrmann
havnt had a chance to check the wiring as yet. looking through the cars history there is invoices for work done on a misfire. interference from ignition was what it was identified as but work was done to put it right... there has been a new rotor and dissy fitted by previous owner
Old May 5, 2015 | 03:58 PM
mrmann's Avatar
mrmann
gapped the plugs at .65 still not right running lumpy.
checked wiring seems fine!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Anutternutter
Aug 21, 2015 06:07 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
