2001 focus ttdi poor cold starting
Old Apr 30, 2015 | 01:57 PM
Charlie Allen's Avatar
Charlie Allen
Default 2001 focus ttdi poor cold starting
Hi and thanks for admitting me to your forum , I have just purchased (cheaply) a 2001 focus estate ttdi , it drives smoothly and idles steadily at 750rpm but it is a bit of a pig to start first thing takes a good ten seconds continuous cranking before firing , thereafter starts on the button all day . It does seem a bit sluggish on hills too but low revs pulls ok . Any ideas would be greatly appreciated before I go on a wild goose chase of replacing things . Many thanks in advance . Oh the mileage is 170000 so I understand things may be worn out
Old Apr 30, 2015 | 05:03 PM
jamie's's Avatar
jamie's
Check the obvious glow plugs etc, but i'd try fitting a rnon-return valve in the line to the fuel pump, as it sounds like the fuel could possibly be running back on it
Old May 4, 2015 | 07:18 AM
LHD220Turbo's Avatar
LHD220Turbo
the fact it starts fine once warm would suggest glow plugs, should be cheap enough to replace assuming you can get them out OK
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
The Enigma
13
Aug 20, 2015 09:38 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
druidgetafix
Aug 15, 2015 10:22 AM
Archiejay
Aug 12, 2015 12:07 PM
