fuel pump voltage
Old Apr 29, 2015 | 02:47 PM
muffster's Avatar
muffster
Default fuel pump voltage
Sorry for the dumb question.
Where at the pump to I check its getting the correct voltage. Car has been stood for a couple of years so just giving it the once over.
Do I check at the 2 terminals at the pump, should I get voltage between these 2 wires or between one and earth. Obviously don't want to disconnect one to test as the pump will stop running.
What's the easiest way to check it?
Thanks.
Old Apr 29, 2015 | 03:16 PM
2Litre's Avatar
2Litre
Yes check at the two terminals on pump one in positive and the other is neg. Tim.
Old Apr 29, 2015 | 04:54 PM
muffster's Avatar
muffster
Ok thanks.
Can I disconnect the terminals for a short time whilst its running to check the voltage. Cant get the probes for the multimeter in past the shroud that protects the terminals?
Old Apr 29, 2015 | 06:45 PM
2Litre's Avatar
2Litre
No because then it won't be running. You need the load of the pump to give you an idea on voltage although ideally its about what voltage you get whilst on boost as the load on the pump will increase (current) and therefore the voltage may drop. But its a good indicator of the state of your wiring to test at idle. T
Old Apr 29, 2015 | 08:06 PM
muffster's Avatar
muffster
Ok, thanks for that 2litre.
So how and where do I get a multimeter in to test it?
Old Oct 26, 2015 | 07:10 AM
jay991's Avatar
jay991
I am also looking at doing this job at the weekend so any ideas to help would be great please
JK12
33
Apr 26, 2021 12:09 PM
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
