engine upgrades
Old Apr 26, 2015 | 02:53 PM
hydro st170's Avatar
hydro st170
Default engine upgrades
I have a 2003 focus st170 and was wondering what the best engine upgrades to do for best power gain and should I leave the remapping till the end? Thanks
Old Apr 27, 2015 | 07:08 PM
mcst's Avatar
mcst
Not much. Induction is supposed to be near on its best already, just a panel filter in the standard box with an air deflector on the slam panel from an auto. Remove the resonator box from the side of the air box for the induction noise.
Everything else ties in to one another. Cam pulley and remap. Exhaust is pretty much spot on stock but not made from a top grade of stainless. Some report loss of power with a decat. Remap makes it more driveable, irons out flat spots etc..
There was a guy on another forum that did everything possible and made something like 1.7hp over factory figures!
Spend the money elsewhere IMHO, uprated brakes, bushes, ARB etc..
Old Apr 28, 2015 | 02:44 AM
hydro st170
Thanks for the information so basically leave exhaust alone and do th brakes and bushes what does ARB mean.Thanks
Old Apr 28, 2015 | 07:45 AM
mcst's Avatar
mcst
Yeah, the exhaust is about as good as it can be its just not made from a high grade stainless like aftermarket stuff. Just get a high performance panel filter in the air box and the air deflector. A remap will make it more driveable, you won't get serious hp gains from it so it's worthwhile just not a high priority IMHO on st170's
ARB is the anti roll bar. You can get uprated ones, iirc whiteline used to do an adjustable one.
Replace as many bushes as you can with poly bushes. A slight drop on good suspension that can be set up properly. Good tyres, lightweight alloys.
Uprate the brakes with drilled/grooved discs and fast road pads, proper braided lines.
Going fast isn't always about pure power, the ££££'s you'll spend chasing extra hp could be spent elsewhere and be more rewarding.
Old Apr 29, 2015 | 01:36 AM
hydro st170
Thanks. Can a turbo conversion or super charger be got and bolted on and would there be much more needing upgraded if I did I know brakes will but anything else? Thanks
Old Apr 29, 2015 | 01:51 AM
Sniffle's Avatar
Sniffle
I thought of the SC/turbo route to. Once you spent all that money you would have been better off just buying a mk1 RS, which has alot better tuning options as well,
also for me the insurance is about the same for ST170 / mk1 RS.
Old May 2, 2015 | 08:39 PM
hydro st170
Thanks people for all the information
Old May 3, 2015 | 02:45 PM
DAN@ADRIAN FLUX's Avatar
DAN@ADRIAN FLUX
Former Sponsor
Hi,
If you find you have issues with insurance for any of the possible engine modifications then please feel free to drop me a line.
Regards,
Dan.
Old May 5, 2015 | 11:06 AM
hydro st170
Originally Posted by DAN@ADRIAN FLUX
Hi,
Regards,
Dan.
Hi Are u a insurance broker or why would I drop u a line?
Old May 5, 2015 | 11:59 AM
DAN@ADRIAN FLUX
Former Sponsor
Hi,
Yes, we are an insurance broker. Adrian Flux Insurance services.
If you wanted a quotation you can drop me a PM with your contact details.
Regards,
Dan.
moesin2005
Jan 23, 2022 06:28 PM
jason_nike
Aug 18, 2019 10:53 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
YODI
Aug 30, 2015 01:12 PM
