My 4x4 cossie started running very rich the other week so after testing the ecu plug voltages I found the tps is at 11.4 volts!! Apparently should be 0.5v closed throttle and 4.5v open throttle. Tried unplugging sensor still the same. What's happened here lol?
check the tps wiring for a short to the live wire on injectors or iscv, hopefully you have an issue there. Otherwise the ecu's output of 5v is fried....
I have seen this before your amal.valve or iscv is shorting out onto the tps wiring Strip back and check.
