3dr brake servo stopped working.
Old Apr 21, 2015 | 08:21 PM
B13 JUS's Avatar
B13 JUS
Default 3dr brake servo stopped working.
Started my 3dr up today and the servo pump isn't working any more, what would be the first things to check? Is there a fuse or relay any where?
Old Apr 21, 2015 | 09:34 PM
Gav Diamond's Avatar
Gav Diamond
Check the wiring to the pump at the bottom or the push on connector..
Had loads of issues with mine till I sorted the connector
Old Apr 21, 2015 | 10:01 PM
Hellraiser's Avatar
Hellraiser
i had same problem as Gav, big wide connector at bottom kept comin loose
Old Apr 22, 2015 | 07:01 AM
B13 JUS's Avatar
B13 JUS
Cheers guys I'll check that
Old Apr 22, 2015 | 03:46 PM
B13 JUS's Avatar
B13 JUS
I've had a good push on all 3 connectors with the ignition on, still not getting the pump going.
Put a multimeter on the pump wires and I'm getting 12v, so I thought it was the pump.
Found an old servo removed the pump and plugged it in but still nothing.
Will it be the pump it self with having power? And the spare pump knackered?
Old Apr 22, 2015 | 06:02 PM
Gav Diamond
Never know of pump packing up, be very unlucky to have 2 dud ones..
Are you sure the plug is making a good connection to the pumps?
Only things I know are poor connection and the fuse/relays under the dash on the drivers side but if you have power then it can't be those
Old Apr 22, 2015 | 07:10 PM
B13 JUS's Avatar
B13 JUS
I'll have another look at it again and give the connectors a clean up and see what happens
Old Apr 25, 2015 | 08:36 PM
Cossy Mike's Avatar
Cossy Mike
Have you got both plugs on the cap plugged in as well? (obviously with enough fluid)
Old Apr 26, 2015 | 08:24 AM
B13 JUS's Avatar
B13 JUS
Yes mike got them plugged in, I'll double check the level but I'm sure the fluid level doesn't stop the pump from working.
I had it out 1 day then the next time I started it the brakes weren't working, no pump working.
Old Apr 26, 2015 | 12:24 PM
dissmalrs's Avatar
dissmalrs
Iv not looked and this is only a theory but if your gettig 12v to the pump is it possible that it is switched on an earth.
And the pump is not getting switched on
Like a say I don't know how these are wired up as iv never looked but dose seem a bit unlikely that 2 pumps are dead
Old Apr 30, 2015 | 08:11 PM
B13 JUS's Avatar
B13 JUS
Anyone know which is the fuse and relay for the abs?
Also what's the 3rd plug on the master cylinder for?
1 plug goes to the pump
1 must be the pressure sensor?
Sp3no
Sep 27, 2015 07:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Cossikev
Sep 13, 2015 02:00 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
